LIP-4WM replacement battery build.
I have one original LIP-4WM battery for my Sony MZ-RH1 MiniDisc player / recorder. I guess I've been pretty lucky, it still charges, but only to 50% capacity. These batteries are not manufactured anymore. Second hand ones can be bought, but the asking price is way too much and there's really no guarantee that you'll get a good battery.
Via google search I found an article with instructions and a free downloadable 3D LIP-4WM battery frame print file for building a replacement battery.
Goto: Hallam Inventions MiniDisc Appreciation and Hacks for the article and file download.
New article and download links:
I've also attached the 3D battery frame file to this opening post in case the archive.org file link stops working.
I don't have a 3D printer and buying one for this small project is cost prohibitive unless you plan to get into 3D printing. Fortunately my local public library offers a 3D printing service and I was able to submit the 3D file and get 2 LIP-4WM battery frames printed. With that major hurdle out of the way, it was really easy to build a couple replacement batteries. In the linked article it is suggested to use thin brass strip for the battery terminals, but I don't think that's a great idea because brass is only 28% as conductive as copper. Using brass would be like adding resistors in the electrical circuit causing a small voltage drop. Instead I chose .999 fine silver to make the battery terminals. Don't go for sterling silver, the silver content is lower and will oxidize (tarnish) faster than .999 fine silver. Copper would be another good choice, but silver is better. Anyway, use what you think is best and fits your budget... I'm sticking with the .999 fine silver.
Materials:
Tools:
.999 fine silver Bezel wire, battery terminals made from Bezel wire, 3D printed battery frame and 402040 3.7Volt 350mAh Li-Po battery.
A closer look. Note that the battery includes over-charging protection circuit board.
Partial assembly showing the wires pulled through the battery frame and soldered on battery terminals.
Final result! Terminals glued in place. The Sony MZ-RH1 being powered by the other LIP-4WM replacement battery.
This was an easy and extremely useful DIY project that didn't take too much time or cost a lot. Of course if I had to buy a 3D printer that would have changed the economics of the project. The original LIP-4WM battery is rated at 3.7V 370mAh, so would last just a little longer than this replacement battery. I'm really happy how the battery turned out and that I can still use my Sony MZ-RH1 well into the future.
Hope this is useful to anyone looking to build their own replacement battery.
EDIT: It appears the above website is offline now, so it would be difficult to read the article and download the battery frame file.
Here's working links thanks to archive.org:
Article: https://web.archive.org/web/2020103...laminventions.com/projects/minidisc-obsession
3D battery frame file: https://web.archive.org/web/20201030101555/https://www.hallaminventions.com/s/SIM-4WM.STL
Materials:
- 3D printed LIP-4WM battery frame
- 402040 3.7volt 350mAh Lithium Polymer battery (ebay purchase)
- .999 fine silver Bezel wire - 1/8 inch (3.18mm) wide, 26 gauge (0.41mm) thickness (ebay or Amazon purchase)
- glue (for bonding metal to plastic)
Tools:
- 3D printer. If you don't have one, maybe use a 3D print service or if you're lucky, your local library offers this service.
- soldering iron + solder
- a few alligator clips or hemostat forceps to hold the battery terminals you made when soldering. You don't want to burn your fingers.
- wire stripper
- diagonal cutter / wire cutter
- needle nose or flat pliers
