Rin1990
- Aug 28, 2015
You don't have to worry about me. I buy many premium iems that already come with high quality cables.
Well, then you're fine I guess. Lol.
Eric hasn't given me a chance to review just yet. I may have to get a loaner from HiFi Headphones here in the UK. Depending on where you are there may be a loaner program for you to access. Keep your hopes up. You very well may be in the same boat as me.
Mm...love to hear about comparison between Horus and PW 1960 Audio 4-wire.
Famous last words. I'll bet that in less than a year Mr. Suyang will be fulfilling your order of "a few" cables...You don't have to worry about me. I buy many premium iems that already come with high quality cables.
Me too! Other properties aside, it's not the best conductor.Am I mistaken or is not gold a bad choice with its higher resistance and as such should not be used in cables? Very curious about more info atm
Gold is not an ideal conductor, that is a verifiable fact. However, conductivity isn't everything. I suggest you try to find Effect Audio at a show, if you can, and confirm for yourself. The cables do not sound the same with similar impedance.Am I mistaken or is not gold a bad choice with its higher resistance and as such should not be used in cables? Very curious about more info atm
Wut?True, but I believe they are using an organic, atomically stable form of artisan gold; the superior molecular structure results in a significantly reduced impedance
