HiBy Link feature for Shanling M1 & M2s & M3s - Wireless control for your DAP
Jun 14, 2017 at 12:47 PM Thread Starter Post #1 of 127
Shenzhen, China
Introducing HiBy Link for Shanling M1, M2s and M3s
Wanted to control your Shanling player over smooth interface of your phone? Wanted to smoothly change volume and songs on your Shanling player without need to bring them out of your pocket?
That and much more is now possible thanks to new HiBy Link feature!
With your phone and HiBy Link app you can control Shanling M1 and M2s in multiple ways:
1) Control playback and volume
2) Browse through folders, albums, artists, genres and songs loaded on your Shanling player
3) Add songs into your playlist
4) Edit playlists
5) Use search function to quickly find
6) View details of played files
7) Share currently played song’s info over other apps(for now supporting Chinese apps like Wechat, QQ, Weiboo)
Please be aware, HiBy link apps is only in beta testing, so some errors and problems might occur. We would be glad, if you can report any problem you find directly to us. With your help, we will be able to make this new wonderful feature smooth and stable.
How to install and set up your player and phone:
1) Download zip file from Shanling website or from Dropbox
2) Update firmware on your M1 or M2s with “update.upt” file. Use standard firmware update procedure.
3) Install included HibyMusic apk file on your Android phone
4) On M1/M2s go to “System settings” -> “Bluetooth” and turn on bluetooth. Scroll to “HiBy Link” and switch it to “ON”
5) On your android phone, turn on bluetooth and go to HiBy music app. Click on HiBy Link icon (second from right in top menu). Turn on HiBy Link with switch.
6) In HiBy Link app, click on search for devices and find your M1 or M2s player and confirm. They will pair automatically.
7) Now your devices are connected and your phone is in charge of your Shanling M1/M2s player!
Update your device to latest firmware to have full support of HiBy Link on iOS.
M2S: https://drive.google.com/file/d/1MQUu2j4sCt57CZOe5MY0DiPakBuHPYeC/view?usp=sharing
M1: https://drive.google.com/open?id=1CsgrDYTtkzNn7d-7DesNy4VKvwon0mEN
M3s: https://drive.google.com/file/d/1lB_YHLvIRAHTCn79wFM66ndAWS7_IPo1/view?usp=sharing
HiBy Link for iOS
Jun 14, 2017 at 1:06 PM Post #2 of 127
Excellent feature. Many thanks! I just got my M2s yesterday and already there's a new and very useful feature. Keep the good work. You're doing very well.
Cheers!
Jun 14, 2017 at 9:48 PM Post #7 of 127
Hi Shanling
I just updated my M1 and to Android Phones, there is no issue to pair via Bluetooth ,and control the M1 via my Android Phone.
Yes, the HibyLink APP on android phone, can only be connected to QQ, WeiBo, WeChat , which I had no issue about that, perhaps it can be extended to support other login.
I noticed today, the APP on my Android phone, doesnt update to the song which the M1 is playing. Is this normal, is it just me? or Is this a BUG?
Introducing HiBy Link for Shanling M1 and M2s
4) Edit playlists
Please be aware, both the player’s firmware and HiBy link apps are only in beta testing, so some errors and problems might occur. We would be glad, if you can report any problem you find directly to us. With your help, we will be able to make this new wonderful feature smooth and stable.
Get your beta firmware at http://www.shanling.com/download/List
Or use Dropbox
M2S: http://drive.google.com/file/d/0B03-whTtNzHmeDZfUlNiTmo4ZVE/view
M1: http://drive.google.com/file/d/0B03-whTtNzHmZjFLZ2tJVTluVG8/view
Jun 15, 2017 at 2:18 AM Post #8 of 127
Hi Shanling
As I said in first post, we are only running in BETA firmware, so sometimes the app on phone or player can missbehave.
Jun 15, 2017 at 3:26 AM Post #10 of 127
Good afternoon friends.
Dear Shanling, mentioned possible problems with the beta version of the software, I hope he does not take offense at me.
Just yesterday, faced with the problem of one of the subscribers of the forum "http: //player.ru" after installing the beta version of the software, its Shanling M2S turned into a brick ...
Collective mind of the forum users found a solution to return the player to working condition, the utility "Ingenic Cloner" was used, technical support Shanling did not remain without participation, I quote their answer:
"Have you ever tried the Brush tool to update M2s?
I have a solution to the problem you can have a try ,Put the 1.10 firmware file into the memory card and Press the play button about 10s. Then M2s will go into the mandatory brush interface..."
Here is a link to this utility "Ingenic Cloner", user manual and firmware for Shanling M2S:
https://drive.google.com/file/d/0B09fkvjsphC7dWNfdk56WjZTejQ/view?usp=sharing
Thus, there are two ways to solve the problems with the firmware, if it arises.
Jun 15, 2017 at 6:22 PM Post #12 of 127
The app disconnect from M2s when I browse the net via chrome. If I use any other app the connection remains and I can use it right away, but if I'm browsing, I have to reconnect to M2s and search for music from zero. The playback does not stops, just losses connection. I don't know if a app issue or it's my phone.
Besides that, I'm very satisfied with this excellent feature. I guess it helps with battery life on M2s since the screen is always off and extend the life of the knob to.
Jun 16, 2017 at 5:01 PM Post #14 of 127
Hi guys, need to give you one update on M2s and our beta firmware in case you would wish to downgrade to older firmware:
We find out one problem when trying to downgrade to older firmware on M2s. If you wish to downgrade, don't use "system update" feature in setting. Instead, put older firmware on SD card, turn off player and then press play/pause button for 10 seconds. This will force automatic firmware update and your M2s unit will be downgraded without problem.
New version of Beta firmware should be ready next week and will fix this problem and other small errors.
Jun 16, 2017 at 5:04 PM Post #15 of 127
Yeah, same thing is happenign to mine. We still have many problems like this in front of us to fix ebfore we get out of beta phase....
It would be useful to be able to add songs or albums to the currently playing cue rather than just to a playlist. Still a very nice addition to the already impressive M1.
Interesting idea, but I'm not sure if we can set up HiBy link to do something that's not working on player itself. But will definitely check with our guys, because this would be really useful.
