iFi audio EarBuddy
Sep 8, 2017 at 2:21 AM Post #17 of 148
2-3 ohm increase is too larhe for sensitive iems. Sound signature will change
I've been using the IEMatch on and off for the last 9 months or so and in the main, it doesn't seem to change the signature on sensitive multi-BA IEMs like the Andromeda or Zeus much, if at all. If the stripped down version works the same way, it's very interesting tech.
Sep 8, 2017 at 11:47 AM Post #21 of 148
@iFi audio - can you provide a comparison between the EarBuddy and iEMatch?
Sep 8, 2017 at 12:49 PM Post #22 of 148
Sep 8, 2017 at 1:11 PM Post #23 of 148
Think of it as an iEMatch Lite.
Lite how? Is the iEMatch a superset? and if so - what was removed in order to create the EarBuddy?
Sep 8, 2017 at 1:15 PM Post #24 of 148
Looks like:
IE match = balanced or SE - earbuddy = SE only
iematch = 2 stage adjustable silence - earbuddy = no adjustment, single volume level
Sep 8, 2017 at 3:31 PM Post #25 of 148
Looks like:
Yup, that's the description, nice work and thanks!
https://www.facebook.com/iFiAudio/ https://twitter.com/ifiaudio https://www.instagram.com/ifiaudio/ https://ifi-audio.com/ https://www.youtube.com/@iFiaudiochannel comms@ifi-audio.com
Sep 8, 2017 at 4:46 PM Post #26 of 148
Looks like:
I understand the Balanced vs. SE only. Thanks.
I wonder whether the "2 stage adjustable silence" vs. "no adjustment, single volume level" means that EarBuddy is ONLY good for sensitive earbuds?
I am only using headphones (not in-ears), and some of them are sensitive / very easy to drive, so I wonder if I would see any benefit from either iEMatch or EarBuddy.
Sep 10, 2017 at 6:14 PM Post #27 of 148
Sep 11, 2017 at 1:09 PM Post #29 of 148
I had problems with regular analog attenuators when I tried to get finer adjustments in stepped volume controls (loss of transparency). Maybe this one would work better.
Ikr? Sounds exciting
Sep 18, 2017 at 4:46 PM Post #30 of 148
The Ear Buddy had a ball at IFA as you know but then sadly had to fly home. Check it out working away with a DAP belonging to one of the team. Shame it wasn't long haul - could have used if for the in-flight movie!
