Introducing SOUNDAWARE Flagship Reference Wireless Network Mobile Player MR1
Dec 16, 2017 at 2:15 AM Thread Starter Post #1 of 60
SOUNDAWARE® Proudly Presents
The state-of-the-art and award winning wireless mobile player !
MR1
Mobile Reference One
Flagship-Class + Full-Balanced + All-Scene Music Playback
For Audiophiles' Unrestrained Enjoyment
Integration of Desktop flagship network and reference mobile players for all-scene applications
Connect via mobile phones apps
via WIFI
via DLNA
via AirPlay
via Bluetooth
With Boost mode, MR1 can perform the same driven effects as desktop player does and play uninterruptedly by using usb external power supply
Use MR1 as a USB DAC to connect your PC-HIFI system
Use MR1 to connect Home Speaker System in multiple ways, control it by mobile phones or tablets
Even MR1 can play with your car stereo system and still be controlled by mobile phones (MR1 3.5mm out---Aux in)
Various Interfaces
①3.5mm balanced headphone out, for a balanced IEM or headphone
②3.5mm single-end headphone out
③3.5mm line & coaxial out, supporting single-end analog output and digital output respectively
④SAW_Link jack(mini HDMI), connected with the customized extension box, can transport XLR full balanced analog and LVDS IIS/DSD signal
⑤The usb jack is for charging or transferring data while adding USB DAC function turns MR1 into your mobile HiFI DAC& amplifier
⑥Two TF card slots, each one supports 256G
⑦Aviation aluminum shell, battery is replaeable
Multiple control modes, diverse wireless applications
High fidelity bluetooth playback integrated Soundaware's unique FPGA independent clock architecture, playback controlled by mobile phones or tablets in wifi mode, optimized Airplay playback on Hifi effect
Adopting the clock and FPGA algorithm from the next generation reference transform system, plus Soundaware's optimization experience to improve the digital output level, using overall unified and more accurate femtosecond clock on Bluetooth and Xmos at the same time
Innovative, professional instrument-grade mono dual-DA symmetric full-balanced, full DC decoding, as well as headphone amplifier system can perform up to the limit of the chip's capacity in no matter the index or the performance
Ultra-low distortion, physically adjustable output power of the full balanced headphone amplifier circuit under load of 16-300 Ω, the distortion + noise can be as low as 0.0008
2 x 3 kinds of gain modes--- headphone amp, pure line and pure digital of three independent output modes, with high-end equipment's fully balanced XLR and native IIS & DSD digital output.
Same as SOUNDAWARE desktop players, MR1 also provides the native DSD&PCM playback with FPGA
More Original Technologies Added
MR1 exclusive SAW_Link extension box interface can make it compatible for various scenes. By using only one cable, it can achieve reference level of digital and analog output to your home speakers and Hi-Fi systems.
The latest FPGA technology with preciser femto clocks was used on MR1. Its original HIFI bluetooth digital processing technique supports APTX and other standards as well. Data transmission through added AirPlay function is lossless, ensuring the sound integrity and quality plays the best. The volume of MR1's AirPlay function can be adjusted by Apple's native design synchronized with the control of MR1, abandoning Apple default volume-control mode which shifts data.
More we've done for MR1
  • Thicker immersion gold PCB of six layers
  • Strictly arranged audio, RF and high speed wires under professional principles
  • Exceedingly rigorous ground segment and return control
  • Analog module and key audio parts are all segmented by two layers complete ground line to ensure the lowest crosstalk
  • Desired good playback effect can all be maintained on all modes.
OEM by Foxconn cooperated factory, the beautiful and exquisite shell, made of aviation aluminum, has passed rigorous CNC production process, while other parts are all produced from high-precise mould.
Every part of MR1 body is of the first-class fine workmanship. Inspired by modern styles, MR1's appearance was designed by professional designers of electronic products, revealing a sense of strength and speed.
More customized extending accessories are supplied.
Battery is replaceable.
Based on SOUNDAWARE popular DAP M1Pro firmware, optimize it and will add gapless playback and more improvements in the future.
Soundaware Stay updated on Soundaware at their sponsor profile on Head-Fi.
https://www.facebook.com/Soundaware-Audio-CoLtd-140035019979865/ https://www.us.soundaware.net/ Soundaware Official market@soundaware.net
Dec 16, 2017 at 3:22 AM Post #2 of 60
Here we comes to Portableaudio Festival-Winter Tokyo Akihabara-2017
Our Booth number is 2F-39, meet us there to try out MR1 and SOUNDAWARE P1-Flagship Balanced
Pre-Amplifier & All Discrete Circuit Full Balanced Headphone Amplifier
(Prototype Picture)
Dec 18, 2017 at 5:17 PM Post #4 of 60
Laptops have wireless stuff in a replaceble form factor. I wonder if qualcomm could make a standard interace for their chips to make devices last longer into the future. I think this Soundaware is really filling a void in audio that has never been possible before. I like.
Dec 18, 2017 at 6:07 PM Post #5 of 60
Dec 18, 2017 at 9:51 PM Post #6 of 60
Looks interesting, what is the expected cost and release date in UK? and can DAP drive Senn HD 6xx?
MR1 would be about $1846
With Saw_Link pack would be $2123
What MR1 does the best is to drive big headphones, flagship headphones with MR1 in high performance mode, you gonna be crazy about it.
Dec 18, 2017 at 9:54 PM Post #7 of 60
Thank you.
Hope you get the chance to try our products.
Dec 20, 2017 at 2:50 AM Post #9 of 60
Sorry.....how much? I thought this overpriced nonsense was disappearing from the DAP world , which has several tried and tested and proven DAPs in the 500 price bracket. It doesn't even look that nice cosmetically to my eyes
Excuse me?
Where did you get that conclusion? Did you try our MR1? If you can get it at 500, I would buy thousands from you.
MR1 has high reputation and stable sales in China mainland, I am afraid the audiophiles won't agree with your came out of nowhere verdict.
Dec 20, 2017 at 4:13 AM Post #10 of 60
£1,326.62 is overpriced for a DAP . Does it have an octa core processor? Can you install the latest version of android on it? Will it outperform a £150 cell phone with a Chord Mojo OTG'd to it? Because the total cost of that would be £550..... Please by all means send me one on demo and prove me wrong
Dec 20, 2017 at 4:49 AM Post #11 of 60
Dear, what MR1 has been usually comparing to is Chord Hugo, not Mojo.
I hope you can get the chance to try our MR1 and let it surprise you. :)
Dec 26, 2017 at 3:49 AM Post #14 of 60
Dec 26, 2017 at 3:53 AM Post #15 of 60
A very appealing player, I'm wondering what some official online retailers are(for English intercontinental) and whether there is any warranty period?
Hi, we will show some online stores and retailer information some days later. I will keep you posted.
And MR1 has a free 2 years warranty with a paid 5 years maintenance service.
Thanks
