- Apr 18, 2016
I can just about guarantee you're not getting the the real benefits if you're not rooted. What's the name of the developer? you have a link?
Viperappstudio, purple viper fx application.
yup definitely a fraud the real deal is https://forum.xda-developers.com/v20/themes/h918-viper4android-t3495134Viperappstudio, purple viper fx application.
How come UAPP sounds SO much better than PowerAmp? Didn't even know about this player. What's the trick? I just had the time to play some MP3 320k, no FLAC/Hi-Res yet. But the difference is kinda huge.
Did you try poweramp beta version? Or a normal one?
UAPP also resample. See detail in email below
Davy is an amazing developer, and UAPP is the best. Davy is getting a v20 shortly and will be able to see this device first hand and how the Quad DAC behaves with the native ESS drivers.
All I can tell you is that when a developer follows the rules, provides all the correct arguments... more often than not, on the v20, output can occur that is native resolution. You can read this thread closely and actually see output from adb dumpsys that demonstrates this behavior. I have posted my findings and tests where sometimes it does not as well, so take note. Of all the players, UAPP n7player and a few others work well in this regard on the v20 specifically -- most of the time.
Bottom line is you need to read the tests, conduct your own tests... listen carefully and see if the output of the system logs correlates to big changes in sound quality. I can listen to music and say that sounds horrible...plug in my phone to the debugger and see that it is resampling. It is that big of a difference and that big of a problem.
UAPP is the only way I can stream hi-res content and have it sound fantastic from a SMB share. It is head and shoulders above the rest because of this.
Good luck!
They use the ESS9218 PRO, it's an audio SoC and not a dedicated/discrete audio DACJust a question here. LG G6 or V20 quad dac has Ess sabre chipset using and that too in quad dac version. Ess sabre 9028 i guess. How does it sound fare against this Opus 11 dac connected phone let's just say iPhone for example ??
