In another thread here at Head-Fi, someone said that harmonic distortion was deliberately added to the Sennheiser HD800S (versus the HD800). That statement was only one of
many (made in the past couple of years) stating the same thing. I had also assumed this to be true, only because it has been repeated so many times here and elsewhere that it's become a generally accepted truth about the HD800S.
But is it, in fact, true?
Last summer, while doing measurements of several headphones, I measured the Sennheiser HD800 and Sennheiser HD800S on the GRAS 45BB-12. As I had also assumed the aforementioned theory to be true, I fully expected to see higher 2nd order harmonic distortion with the HD800S versus the HD800.
However, any increase in harmonic distortion was minor (HD800S versus HD800), and I didn't see anything in the distortion product ratio plots that supported the theory / assumption. Further, when I brought up this topic with Sennheiser's Axel Grell in London (at CanJam), he was not surprised by our measurement results, as he said there was no deliberate distortion added to the HD800S.
Things got busy at the show, and I hadn't given that specific topic a lot of thought since, until I saw it stated as fact again the other day in another thread, where a few of us then discussed it briefly (see quotes immediately below):
So I decided to examine this further here, with the HD800 and HD800S we have, and using a completely different measurement head fixture than I used when I did the measurements last summer (details of the measurement system used can be found at the bottom of this post). Here's what I did:
- Guided by the FFT plot at InnerFidelity, where we first read about this theory / assumption, I first I did a quick FFT plot of the HD800 (16,000 points, no averages), playing a 40 Hz sine wave. I ended up with a plot that looked somewhat like this:
As you can see, that's not particularly detailed, so I took advantage of our audio analyzer's ability to do extremely detailed FFT's, opting for 1.2 million points, and doing three averages. Setting it to 1.2 million points provides a much more detailed plot, and the averages help remove random noise (better revealing the actual noise floor, too). Without having moved the HD800 from the above plot, here's the FFT re-run with 1.2 million points with three averages:
And here are the two overlaid:
NOTE: The examples above are actual measures of the Sennheiser HD800, but these were just quick preliminary measurements done without turning off the building's heating / ventilation systems. Even though we do employ a lab-grade acoustic and vibration isolation enclosure, the measurement gear is obviously very sensitive, so we still turn off the HVAC systems when we're doing audio measurements to lower the noise floor. As a result, the example measurements above may have a higher noise floor than the measurements that follow (which were done with the building's HVAC systems turned off).
- Again, the above measurements were just done as examples of two different FFT resolutions. Now let's get to the actual comparisons of our HD800 and HD800S. Following are FFT spectrum measurements from the first seatings of the Sennheiser HD800 and Sennheiser HD800S, set to 1.2 million points and three averages, and playing a 40 Hz sine wave. I made the plot lines a bit thicker (and different colors) to try to make the two plots easier to distinguish from one another:
Here (below) is the same plot with cursor lines showing the difference at 80 Hz (80 Hz being the second harmonic of the 40 Hz sine wave fundamental tone, since we're examining the theory that the Sennheiser HD800S's richer sound is due to (as quoted above) deliberately added 2nd harmonic overtones/distortion):
The difference between the Sennheiser HD800 and Sennheiser HD800S at 80 Hz (H2) is only 2.783 dBSPL. Keep in mind that the center of this 2.783 dBSPL difference is occurring around 45 dBSPL lower than the fundamental tone. While the Sennheiser HD800S unit we have here does (to my ears) sound like other HD800S's I've heard (richer than the Sennheiser HD800), I do not believe this measured difference at 80 Hz suggests deliberately added 2nd harmonic overtones/distortion (to the HD800S versus the HD800).
- I decided to do a second seating of both headphones, also increasing the size of the headband for both headphones by one click on each side. Here (below) are the FFT spectrum plots from the second seating:
Again, this time (below) with cursor lines showing the difference between the two in this seating at 80 Hz (the second harmonic of the 40 Hz fundamental test tone):
The difference in this plot at 80 Hz is lower than the previous one, measuring only 1.673 dBSPL. As above, the center of this difference is about 45 dBSPL below the 40 Hz fundamental tone.
Again, keep in mind we only have one Sennheiser HD800 and one Sennheiser HD800S here at this time. I may measure more. (
NOTE 2018-01-02: I did measure another HD800 later, and you can see it by clicking on the following link:
Additional Sennheiser HD800 FFT measurements.)
Based on discussions with Sennheiser and the above measurements of the Sennheiser HD800 and HD800S we have on hand, it does not appear there was any deliberate addition of 2nd order harmonic overtones/distortion to the HD800S as has been the common theory for the past couple of years.
If you have any other suggested tests you'd like to see performed on these two units here that you think might generate different results, let me know. That said, based on the THD measurements I posted in this thread earlier, and other measurements we've performed on these two headphones (also on the GRAS 45BB-12), I'm not surprised by the above results.
The measurements in this post were made using:
NOTE 2018-01-02 00:56 EST: I measured a second Sennheiser HD800 and (with those measurements) offer a possible explanation for how this theory of deliberately-added higher 2nd order distortion in the Sennheiser HD800S may have come about. Long story short, our measurements so far do
not support the assumption that Sennheiser added 2nd order harmonic distortion to the HD800S, which is also consistent with feedback from Sennheiser. You can find out more at the following link:
Additional Sennheiser HD800 FFT measurements, as well as a closer look at the measurement that started this assumption nearly two years ago.
