[FiiO BTA30Pro] Create a Comprehensive Home Bluetooth System, FiiO's High Fidelity Bluetooth Transceiver BTA30 Pro!
Oct 26, 2021 at 8:20 AM Thread Starter Post #1 of 372
FiiO
Sponsor: FiiO
Guangzhou,China
After the global chip shortage, the BTA30 released last October has faced an upgrade. Besides, many audiophiles have more needs for audio setups, such as higher sampling rate under USB DAC and Bluetooth support for LDAC. This time, the upgraded BTA30 Pro will be in place.
The BTA30 Pro not only supports devices of LDAC reception and transmission, but also supports LDAC transmission under USB in and SPDIF in. You can easily get Hi-Res lossless audio anywhere and anyhow.
The XMOS receiver chip easily handles a wide variety of audio formats up to 384kHz/32bit PCM and native DSD256, allowing you to enjoy it worry-free.
The all-new high-performance ES9038Q2M DAC is superior to the last-gen in performance, audio details, as well as dynamic range than those of portable audio products. Film capacitors work with the ES9038Q2M DAC for clearer and more transparent treble.
In addition, there are many news functions added, such as Bypass mode, one-button switching between input sources, one-button selection between sound quality priority/latency priority, one-button switching to conveniently choose between 6 formats in Bluetooth Transmitter Mode, helping to create a comprehensive home Bluetooth system for you!
Keep features of the FiiO BTA30 Pro include:
--ES9038Q2M DAC
--High performance DSP
--Qualcomm CSR8675
--XMOS receiver chip
--Transmit and receive LDAC
--Supports up to 384k/DSD256
--RGB indicator
--APP remote control
*The BTA30 Pro is available on our AliExpress Official Store. Click the link below to take it home right away.
https://www.aliexpress.com/item/1005001677949000.html
Best regards,
Guangzhou FiiO Electronics Technology Co., Ltd.
Oct 26, 2021 at 2:38 PM Post #2 of 372
Congratulations for your new product.
Maybe this is an obvious question, but I would like to know if it can be used as a Bluetooth transmitter, when connected as a DAC to a PC. My most common scenario is to use my PC with Foobar2k, because I have a large library of audio files on it and to be able to have the freedom to use my best TWS.
Regards.
Oct 26, 2021 at 9:39 PM Post #4 of 372
Ummmm...Is this device capable of simultaneously broadcasting a BlooToof signal to multiple speakers throughout one's home?
That is all I want to know. It does look cool...I know. Shallow Toad. :beerchug:
ORT
Oct 26, 2021 at 11:56 PM Post #5 of 372
--ES9038Q2M DAC
--Qualcomm CSR8675
--RGB indicator
Best regards,
Link appears to be to the older, non-Pro model.
Oct 27, 2021 at 5:43 AM Post #7 of 372
Regards.
Yes, it is supported in the BTA30Pro.
Best regards
Oct 27, 2021 at 5:47 AM Post #8 of 372
ORT
Which input and output at that time?
USB DAC in: line out, coaxial output and optical output can all work at the same time.
Optical in (BYPASS mode): line out, coaxial output and optical output can all work at the same time.
And the BTA30Pro could connect to two Bluetooth devices simultaneously in TX or BT mode.
Best regards
Oct 27, 2021 at 5:48 AM Post #9 of 372
Yes, the introduction pictures in the Aliexpress link hasn't been updated to BTA30Pro yet. We will update it soon.
Best regards
Oct 27, 2021 at 8:50 PM Post #10 of 372
"transmit and received LDAC" hmm, does this feature included in the non-pro? I couldn't recall.
Oct 28, 2021 at 12:00 AM Post #11 of 372
In BTA30 LDAC is not support when using USB in. Now the BTA30 Pro supports this feature.
Best regards
Oct 29, 2021 at 3:05 PM Post #12 of 372
So SBC, AAC, aptX, aptX-HD, aptX LL, LDAC are still supported in transmission mode, regardless of digital input? What bitdepth and sampling frequency PCM over USB is supported when in transmission mode? Will the volume knob work when input from USB and transmitting to a BT headphone?
Oct 31, 2021 at 11:10 PM Post #13 of 372
Dear friend,
1. SBC/aptX/aptX LL/aptX HD/LDAC Bluetooth codecs are supported in TX mode.
2. USB in supports up to 384K/32bit;DSD256(dop)
3. The volume is adjustable in USB in Bluetooth output mode.
Best regards
