Bit Perfect Audio from Linux
Feb 25, 2023 at 7:07 AM Post #541 of 550
I have not found anything that can play SACD ISOs on Linux. Can anyone recommend a good player comparable to Foobar2000?
Sorry late to the party, don't if it has been answered: JRiver Linux
May 1, 2024 at 10:08 AM Post #544 of 550
I updated the AUR repository. There are still some problems with it, as the upstream is almost 1 year old, but I tried to fix it.
DVDA ISO playback temporarily disabled. (I have no idea which dependency it requires)
May 12, 2024 at 10:11 PM Post #545 of 550
Guys any app other than DeadBeef player which plays bit perfect audio in Linux, got fed up with DeadBeef as it doesn't provide any library feature for browsing my music, tried Rhythmbox and Clementine both resamples the audio so can't use it.
Quodlibet would be the desktop app I recommend. LMS would be the full on music server program I would recommend.
May 12, 2024 at 10:31 PM Post #546 of 550
My first post offered some tools to narrow down issues with the audio path. If I use both pulse audio and ALSA, I want to make sure my music player uses ALSA and doesn't mix the sound. For me, this is my only concern.
In your post #498 you are asking for proof that Linux offers bit-perfect sound. The question suggests that Linux isn't capable of outputting bit-perfect audio.
While I can't proof or disproof bit-perfect audio under Linux, at least not right now, I suggest to look at what vendors of top end audiophile music players are selling you: essentially Linux boxes.
I didn't do an all inclusive survey, but have a look at aurender, Lumin, Music Fidelity, Naim, and probably more. There are exceptions too: Taiko Audio Extreme runs a Custom Windows 10 Enterprise LTSC OS.
With music server vendors that run Linux, you have to look for the small print to identify them as Linux servers. I guess Linux still carries the stigma of a nerd OS.
I hope you accept this indirect answer. It's not a proof (perhaps someone else can proof it). My other post may help narrow down issues with your Linux audio configuration.
I think he's missing the point in a big way, and I think y'all are wasting your time trying to talk sense into this guy. He essentially think that "bit perfect" audio is some esoteric, mythical thing... it's not. It's very simple. Does it output digital audio at the original sample rate without conversion or EQ? If yes, then congrats you've got bit perfect audio. That is exactly what happens when you output to an ALSA hardware. Want proof? Well, that's what it was designed to do and it's not broken... so there you have it, bit perfect audio. Don't believe me? Go read the source code and see exactly what it's doing.
End of discussion. If that's the designed behavior, burden of proof is on him to prove that is not what it's doing.
Dude's just making his life way more complicated than it needs to be in order to feel special, and y'all are playing right into that.
I'm sure I'm about to be insulted, I'm ready. Let's go.
May 31, 2024 at 12:55 AM Post #547 of 550
ALSA does play bitperfect (when you max out the volume), but not if you use pulseaudio on top, beside this i really have to recommend pipewire here, much better than pulseaudio
since i use pipewire:
pipewire runs like windows on one samplerate (default behaivor), the samplerate can bet set to whatever you like, pipewire will resample all audio streams to the set samplerate, i think as far i remember this is also how pulseaudio works but with a not as good resample algorithm
with pipewire you can also have following setup:
the first stream played deteremines the samplerate pipewire runs in, additional streams get resampled to the samplerate of the first stream, this essentially allows you to stay bitperfect (for the first stream and additional streams with the same samplerate) if you max out all digital volumes (browser, pipewire, alsa (pipewire should handle alsa))
i also recommend to max out the resample quality, this makes a nice difference if you set pipewire to resample everything to 176,4khz, not sure if this has changed but around a year ago 192khz was max samplerate for pipewire
May 31, 2024 at 12:56 AM Post #548 of 550
also it has to be said that most dedicated linux streamer dont use either pipewire or pulseaudio, they run only with alsa, which is as bare bones you can go
since i use a normal PC, i kinda have to use pipewire or else its really inconvienent
Jun 2, 2024 at 11:30 AM Post #549 of 550
Correct. Pipewire and Pulse are designed for general desktop use and convenience. If you have a USB DAC, you can easily have your player or choice directly use it via ALSA for ideal bit perfect playback while using Pulse or Pipewire for the rest of the system audio with another device.
Jun 2, 2024 at 12:01 PM Post #550 of 550
Ah yes, true... HQPlayer uses the alsa devices directly for example
