I might be selling mine!Hi, @FiiO! Is the LC RE Pro 2022 available from any vendors in America, or only on AliExpress?
[FiiO LC-RE/LC-RE Pro/LC-RE Pro 2022] MMCX cable Gold-Silver-Copper swappable plug Earphone Cable
- Home
- Forums
- Head-Fi Special Forums
- Premier Sponsor Forums and Sponsor Forums
- FiiO
- Thread starter FiiO
- Tags
- fiio fiio lc-re
e-dub
@FiiO, will you be selling a version of the LC RE Pro 2022 with black metal MMCX connectors, to match the dark FH9? The current one matches the silver, but not the black. Thank you!
David Auctioneer
Mine has gotten green too, are you absolutely sure that the oxidization has no influence on sound? I believe that this is a lack of quality control; I have never worn these cables outdoors, as I only use them at home or when overnighting in a hotel. I have contacted the seller, and will ask about the warranty as I bought them in Feb 2021.
I could consider putting a sleeve on them, because the green looks shabby...
tomi1976
- Apr 29, 2014
I got the cable and as I understand it is applicable on the Sony ier z1r, I read that removing them can be a problem and there is a danger on damaging the mmcx connector on the sony
Any experiences or tips on that?
thank you and cheers
purk
- Sep 26, 2001
I don’t recommend them with the IER-Z1R because removing it is VERY difficult and grip is very tight b/w the male & female connector. The old RE version is a little easier to remove but the LC PRO and PRO 2022 are almost next to impossible unless you are willing to do the following mod due to the smoothness of the stainless steel connector. What we are dealing with is a recessed MMCX socket and near frictionless surface of the stainless steel. You just simply have no place to grab on. I installed a heatshrink tube at the FiiO connectors so it is easier to remove now. I also use the FiiO MMCX removal tool with it. Below is my recently acquired photo of my LC RE Pro 2022 with the IER-Z1R. Excellent match really. What a wonderful sounding cable!
tomi1976
- Apr 29, 2014
Ok, so with a grip the cable is removeable?
This needs to be applied before inserting the cable? Wouldnt any sticky rubber band do the same job when removal is to be done without permanent heatshrink tube on or is the grip not good enough without shrinking?
And would you recommend it with the mod or is that still risky because of the diameter if the mmcx housing of the ier z1r regardless of the new gained grip?
Thank you for the advise!
Cheers
Cheers
purk
- Sep 26, 2001
Yes, it is all about an increase a grip and a place that your thumb and index finger can grab on to. I use heatshrink tube with an adhesive liner. I also leave a little space between the top of the socket and FiiO connector so the MMCX tool remove can get in between. I have not thought about a rubber band, but you try as well.
- Jun 26, 2001
I’ve just pulled the trigger on the LC-RE Pro 2022 for my FiiO FD7…
From my understanding, this will be an upgrade beyond even the FiiO FDX - so, quite excited to hear the difference!
- Jun 26, 2001
hammondfan
Hello, this problem of oxydation reminds me of what systematically happens with the shure se 845 cable it is an awfull experience. For me the listening experience is a whole, like eating, the eyes play a role too, who doesn't like to hear good music with a glass of wine, old whisky or cognac, I couldnt enjoy the listening with a green looking cable looking like moist ... I dont understand if that happens on the 2022 model ? That would be.a nogo for me !
scracy
No oxidation has occurred on my LC-RE Pro 2022 or the previous version both of which I have owned for around 12 months.Hello, this problem of oxydation reminds me of what systematically happens with the shure se 845 cable it is an awfull experience. For me the listening experience is a whole, like eating, the eyes play a role too, who doesn't like to hear good music with a glass of wine, old whisky or cognac, I couldnt enjoy the listening with a green looking cable looking like moist ... I dont understand if that happens on the 2022 model ? That would be.a nogo for me !
hammondfan
Thank you @scracy for your feedback !No oxidation has occurred on my LC-RE Pro 2022 or the previous version both of which I have owned for around 12 months.
I would appreciate if fiio gives me a feedback on that potential issue ?
Also how would it synergize with the final audio a8000 which is "King of treble" ?
David Auctioneer
I think it may have something to do with my nickel allergy and the permeability of the silicone sheath?, although this may not occur. No reaction or feedback from Fiio. The cable is no longer in use, because it got worse and worse. Last product I will ever buy from them. Shame though, it is a fantastic cable with a handy connector plug.Thank you @scracy for your feedback !
hammondfan
Are you talking about the lc re 2022 model with golden wires ?I think it may have something to do with my nickel allergy and the permeability of the silicone sheath?, although this may not occur. No reaction or feedback from Fiio. The cable is no longer in use, because it got worse and worse. Last product I will ever buy from them. Shame though, it is a fantastic cable with a handy connector plug.
David Auctioneer
it was their first LC-RE..silver, copper and gold plated, like a nice tri-color design.. a shame, I really loved that cable..Are you talking about the lc re 2022 model with golden wires ?
- Home
- Forums
- FiiO
