There are some instructions and troubleshooting suggestions in hm1000 thread which uses the same app.I just received one of these and am have a bit of trouble trying to understand how to use PC assistant. I have this link https://tools.hifiman.cn/hifimanremote/pcassistant.html
but I don't know what I am looking at or where to start. Thanking you in advance for any help you can offer.
Hifiman HM901R R2R DAC
searchingtom
I have been playing this for a couple of hours now and all I can say is WOW:
1) The sound is REALLY good !!
2) This thing is VERY light.
3) I only paid $300 for this !
Unreal.
Great job HIFIMAN !!!
Unreal.
Sulbh
- Jan 12, 2014
Which amp card are you using?I have been playing this for a couple of hours now and all I can say is WOW:
Unreal.
searchingtom
Also just bought these on their way from China:
Sulbh
- Jan 12, 2014
Which one do you prefer?Also just bought these on their way from China:
searchingtom
Only have the originally supplied and the balanced here so far. The balanced sounds better for headphones.
Sulbh
- Jan 12, 2014
Did you buy these from Hifiman's website or Aliexpress?Only have the originally supplied and the balanced here so far. The balanced sounds better for headphones.
searchingtom
Aliexpress.Did you buy these from Hifiman's website or Aliexpress?
Just wanted to share my discovery. Apart from Hifiman amp cards, i have tried other oem cards as well. Tried Ufeel MK3 and Honor 3. Can safely say the honor 3, is much better than hifiman's own balanced card. Honor 3 is the purple card shown in Aliexpress store. Wayzr and way-zr2 are on their way. Will update once i received them.
imacaverage
please indicate the model of headphones on which you came to such conclusionsJust wanted to share my discovery. Apart from Hifiman amp cards, i have tried other oem cards as well. Tried Ufeel MK3 and Honor 3. Can safely say the honor 3, is much better than hifiman's own balanced card. Honor 3 is the purple card shown in Aliexpress store. Wayzr and way-zr2 are on their way. Will update once i received them.
a balanced card has a non-zero output impedance, so the sound is very bad on multi-driver armature headphones with a non-linear impedance, but on dynamic headphones it’s a completely different story
My bad and you’re right. Many of the amp cards will not have zero output impedance. And BA drivers based iems will suffer the most. FWIW, i am using SoundRhyme SR8 (14BA) with 4.4 plug. Compared to balanced card, this card (honor3) really have minimum background noise.please indicate the model of headphones on which you came to such conclusions
imacaverage
searchingtom
Sulbh
- Jan 12, 2014
Hi why did you sell it? Was it not good?
Total: 6 (members: 0, guests: 6)
