I need help finding a USB switcher or selector.here is what I plan to do with it.
So I want to use my main PC, Eversolo Streamer, SmartPhone & Extra source for Reviewing new equivalent.
Here is the chain:
4x Sources Connected via USB into>
A USB Switcher Device or USB selector Device>
Would go out via USB to 6-8 DAC/Amp combos.
The point of this is to be able to use different sources on different DAC/Amp combos. These amp/DAC combos will be reviewed or used for testing/reviewing different headphones.
I need help finding a switcher or selector. Most seem to only be used for USB devices to be shared with PC's. I want to be able to select which source I want to use and also which amp/DAC combo. That may seem like too much to ask from my search.
Thoughts Ideas or switchers, selectors, hubs, matrix's you think may work?
I appreciate the help. I think I've oversearched it all night long and now I can't seem to see anything that'll work. I probably just need a few new fresh set of eyes on to help me.
Thanks in advance.
Here is the chain:
Thanks in advance.
