Hifiman HE1000 Planar Dynamic Headphone
May 8, 2024 at 5:53 PM Post #14,671 of 14,741
Are you referring to adi 2 FS?
Are you driving the he1k from it?
it's the ADI-2/4 Pro SE, but the FS also ran the HEKS with zero issue. Not even close to max volume.. people really overestimate headphone power requirements. I'm at like 50% high gain on the WM1ZM2 and it only puts out 500mw.
May 8, 2024 at 6:05 PM Post #14,673 of 14,741
It is not possible to get full efficiency from heks with portable music players (especially Sony). If you can't tell the difference, you should question your hearing. You will be wasting your money.
Whatever helps you sleep at night 😂
May 10, 2024 at 12:28 PM Post #14,674 of 14,741
Hey all - I made my own stand for HE1000s, so they can rest without hanging from the suspension strap. I uploaded the file to Printables which I'll link below, so anyone here can download and 3D print it yourself. I also made other versions for the Arya, Ananda, and Edition XS.
Link to download the STL: https://www.printables.com/model/875341-hifiman-headphone-stand-he1000-arya
May 10, 2024 at 2:17 PM Post #14,675 of 14,741
Very cool, might have to make one, I am quite into making stands, did this one recently
May 11, 2024 at 3:12 AM Post #14,677 of 14,741
Very nice indeed, how the hell did you do that, it looks very intricate to me?
May 11, 2024 at 3:40 AM Post #14,678 of 14,741
I used a laser cutting machine I have at work, it’s not perfect but not bad for a first attempt. There is a recess in the base where I fitted a battery led light. It’s made from thin oak sheets, acrylic & mdf.
May 11, 2024 at 1:24 PM Post #14,680 of 14,741
The only marking I found was on the box where it says 'Stealth Magnet Edition'.
(Edit: Oops, 'Stealth Magnets Design', I was going from memory.)
May 11, 2024 at 1:31 PM Post #14,681 of 14,741
Hello,
Does someone has the waterfall curve of the he1000v2 ?
I got mine yesterday, used in very good condition, but how is it possible to know for sure which version it is ?
Thanks you.
What box and packaging did you get? The v2 comes in a leather box with three cables and a booklet with a sheet which has the serial numbers of the drivers.
May 11, 2024 at 4:25 PM Post #14,682 of 14,741
I dont have a leather box, but it comes from the french importer with a bill that says v2 stealth.
It is quite efficient as I have almost the same output as with my Neumann ndh30.
Pretty bright though but I use eq so no problem.
Staging is really good and now I have fast tight extended bass. The treble to have a laid back listening experience.
I have a target which is slightly tilted down.
May 11, 2024 at 5:31 PM Post #14,683 of 14,741
Those are Stealths. The two stickers tell you that it's both Nanometer diaphragms and Stealth Magnets. Best ones pretty much hands down imo.
May 11, 2024 at 8:38 PM Post #14,684 of 14,741
