Introducing the SMSL A50 PRO 2.1 Channel MA12070P*2 BT5.0 HDMI ARC Power Amplifier
May 17, 2024 at 10:38 PM Thread Starter Post #1 of 1
smsl mandy
Sponsor: S.M.S.L
shenzhen,china
SMSL A50 Pro 2.1 Channel Power Amplifier only 89.99$​
Experience superior audio performance with the SMSL A50 Pro 2.1 Channel Power Amplifier, featuring advanced connectivity options and versatile controls.
High/Low Pass Filter​
The amplifier includes adjustable high-pass and low-pass crossover points, ranging from approximately 50Hz to 600Hz, with 10 selectable crossover points each. This allows precise control over the frequency distribution, and the volume of the passive subwoofer can be adjusted independently.
Versatile Connectivity​
The SMSL A50 Pro supports multiple devices with its USB-C port for driver-free use, HDMI (ARC) compatibility with most televisions, optical input for audio with 24bit/192kHz code rate, and AUX input for various audio connections.
Seamless HDMI(ARC) Connection​
Connect the amplifier to your TV's HDMI port for seamless audio return without any setup. The amplifier's volume is synchronized with the TV, ensuring noise-free volume control.
Adjustable Passive Subwoofer​
The SMSL A50 Pro provides 100 watts of passive bass output power, with adjustable volume control ranging from 0 to 99. It effortlessly handles various speakers and scenarios, delivering powerful bass performance.
Bluetooth 5.0 Support​
The amplifier supports Bluetooth 5.0 connectivity, allowing easy pairing with smart devices. Once paired, subsequent connections are automatic.
Multiple EQ Presets​
Enjoy a diverse listening experience with multiple EQ presets tailored to various music styles. Bass and treble adjustments are also available, with a customizable range of +9 levels.
MA12070P Ultra Power Efficient IC​
Equipped with 2 MA12070P ultra power efficient ICs, the amplifier offers unparalleled power efficiency, HD audio quality, and low interference. It is flexible and configurable for various applications, including portable audio, home audio, and pro audio systems.
S.M.S.L Stay updated on S.M.S.L at their sponsor profile on Head-Fi.
https://www.facebook.com/S.M.S.LOfficiaI https://twitter.com/SMSL_Official http://www.smsl-audio.com/ smsl_mandy@126.com
