Shanling M6 Ultra - 4x AKM AK4493S DAC, Snapdragon 665, Android 10 DAP
Mar 16, 2024 at 12:46 AM Post #859 of 895
does CFA IEMS Vega 2020 or Solaris 2020 hiss with this?
I don’t know about those particular IEMs but with mine there is zero background noise
Mar 28, 2024 at 8:42 PM Post #860 of 895
Does anyone have issues running Apple Music? Suddenly showing that the device is rooted.
Mar 29, 2024 at 1:56 AM Post #861 of 895
Apple included this curious block in their latest V4.7.0 release. We reported it to our software team and they are working on a fix.
Meanwhile, we recommend to switch to V4.6.0 version of the app, which works without issue.
Apr 8, 2024 at 9:14 AM Post #863 of 895
Did anyone solve a problem with Apple Music complaining the device is rooted? It looks like it broke when I replaced a flash card, but I'm not sure. Not the end of the world, but it would be handy to make it work again.
Upd: I've forgot the app had an update. Thanks @kumar402
Apr 8, 2024 at 9:16 AM Post #864 of 895
Apr 10, 2024 at 4:28 AM Post #865 of 895
Apr 10, 2024 at 10:25 AM Post #866 of 895
Apr 10, 2024 at 10:58 AM Post #867 of 895
How long does the update take? I downloaded it and it's been running for about 20 min.
OK - reboot and restart the upgrade worked. 45 min of play and no issues to report.
Apr 11, 2024 at 12:44 AM Post #868 of 895
Apr 24, 2024 at 9:10 PM Post #870 of 895
Im using this the new XD05 pro when using the Ultra in the line out mode do i need to use it with the usb-c out only or can i use it with the 4.4 and 3.5 out without it using the amps in the ultra .
You can test it out to compare which DAC is better.
