Geshelli is a very small family operation. Your best bet would be to email them directly and ask if they will sell you one (with your required voltage).Geshelli mention on their HP:
Initially the Zoofa and Dayzee will be released in US/Canada only. Freight Forwarding orders will not be accepted. Thank You!
Does someone know if this changes in the future, so we can order the Dayzee in Europe?
Thx
Dayzee - Flagship DAC from Geshelli Labs
- Thread starter Promee
How much is the Dayzee in the most basic version?Building on the tremendous success of the J2 and J2S DACs, Geshelli Labs have turned things up to 11 with their new flagship Dayzee DAC.
Thx
IIRC, Geshelli mentioned a basic price of 1300$ in a YT video.How much is the Dayzee in the most basic version?
If this is right I am wondering about Dayzee's SQ in comparison to Geshelli's lower priced DAC and the same DAC chip with these Sparkos:
https://www.head-fi.org/threads/geshelli-j2s-dac-and-sparkos-ss2590-yes.970743/
I think that’s about right for the base price with standard op amps and basic case. I don’t have a J2S to compare, but I do have an E70 Velvet with the same DAC chip, but only one of them (like the J2S) as opposed to the 2x chips in the Dayzee. I doubt the E70V is as good as a J2S in sound quality, but it is probably not miles apart. I am planning to do some more detailed comparisons, but life keeps getting in the way the past couple of weeks… The Dayzee is definitely superior to the E70V overall, but I haven’t listened to the E70V in a few weeks, so I will need to get them side by side to give more detail…IIRC, Geshelli mentioned a basic price of 1300$ in a YT video.
I just got the pricing of the Dayzee by Sherri starting at $1300. They mentioned that all eight opamps are tied together, so I would have to replace all eight.
I thought initially it might be possible to replace only two standard mono opamps by SS2590 as I use only one set of RCA as output but this seems not to be the case.
- Oct 18, 2016
Thx
Why? That's an insular decision.
I don't know, their Dayzee page isn't yet updated:Why? That's an insular decision.
https://geshelli.com/dayzee/
I had the same question and that’s the same info I received. I think they are configured differently in this DAC. Each slot seems to have traces on the PCB to different pins on the op amps, so they may be performing different functions that are complimentary. Honestly way out of my depth on that, but based on the physical location of the op amps, it is not clear that any of them are associated with any particular output - they’re more in the middle of the board close to the DAC chips…I just got the pricing of the Dayzee by Sherri starting at $1300. They mentioned that all eight opamps are tied together, so I would have to replace all eight.
It would be nice if Geshelli shed some light on the opamp configuration with the SS2590 in the Dayzee.I had the same question and that’s the same info I received. I think they are configured differently in this DAC. Each slot seems to have traces on the PCB to different pins on the op amps, so they may be performing different functions that are complimentary. Honestly way out of my depth on that, but based on the physical location of the op amps, it is not clear that any of them are associated with any particular output - they’re more in the middle of the board close to the DAC chips…
They have said that they’ll definitely have plug and play sockets for the SS2590 to make them easy to drop in even if they aren’t selected during purchase, but I’m guessing that they’re using multiple channels in each of the 2 DAC chips for processing the one channel of audio (left or right), so they need the op amps to match to have balance… of course more detail is always appreciated if they’re able to share!
Did someone listen to the Dayzee at AXPONA?They have said that they’ll definitely have plug and play sockets for the SS2590 to make them easy to drop in even if they aren’t selected during purchase, but I’m guessing that they’re using multiple channels in each of the 2 DAC chips for processing the one channel of audio (left or right), so they need the op amps to match to have balance… of course more detail is always appreciated if they’re able to share!
Did someone get some info why they use eight opamps?
Thx
Huntersknoll
I don't think I've ever looked at a DAC and said, "Wow, that is a great looking DAC!" but Wow, that is a great looking DAC!
Going to be on the top of my list once I get a new AMP. I'm a sucker for wood.
No info on the 8 op amp thing yet unfortunately…Did someone listen to the Dayzee at AXPONA?
Thx
Started to write the review for the Dayzee, but it turned into a roundup featuring the Dayzee, the Denafrips Ares 12th, Chord Qutest, and Topping E70 Velvet. I will still plan on writing a review on the Dayzee, but for now here’s the roundup if anyone is interested!
https://www.head-fi.org/threads/dac...-12th-chord-qutest-topping-e70-velvet.972824/
uncola
- Oct 5, 2007
mine is scheduled to arrive on monday! the only dac I have on hand to compare it to is an eversolo dmp-a6 master edition with beatechnik linear power supply inside. I'm not great at describing sound differences but I'll try
