JM Audio Editions XTC Headphones
May 8, 2024 at 4:18 PM Post #1,111 of 1,229
May 11, 2024 at 2:14 PM Post #1,112 of 1,229
Listening to a pair of XTC 2.5’s right now and am loving them! Looking forward to you getting a pair of 2.5’s and hopefully hearing how they compare to your ZMF’s!
May 11, 2024 at 9:03 PM Post #1,113 of 1,229
John was kind enough to send me a pair of his new pads for the XTC2’s to try out. I have been using the fuzzy pads, which I love. The new ones are quite a bit thicker moving the driver further off your ear and with more volume inside the pad. The effect is not subtle in my case. It in essence lowers the noise floor with all the associated effects - more of everything to put it simply. I ordered a second pair for my other XTC2’s. Now John just needs to do a fuzzy version! 🤣 Do give them a shot - who knew pads can make such a diff. 🤷‍♂️
May 11, 2024 at 9:05 PM Post #1,114 of 1,229
Are the new pads on the site?
May 12, 2024 at 12:05 AM Post #1,116 of 1,229
May 12, 2024 at 12:37 AM Post #1,118 of 1,229
May 12, 2024 at 10:00 AM Post #1,120 of 1,229
Wow. Amazing headband pad.
Sorry, which website? Where did you get it from?
Turbulent Lab. Keep in mind not a perfect fit so a little mod required cutting to size. It also depends a little on the version of the headband you have from John. In retrospect may have been easier to just get the Audeze headband. The leather strap it comes with is nice and soft. I got the carbon version for one pair that just did not quite work as the metal part was just too thick and not flexible enough to bend to shape. I only put the new leather strap on there because I already had it. The strap the Audeze comes with is fine. See pic.
May 12, 2024 at 10:08 AM Post #1,121 of 1,229
The carbon version works great if you have a big head. If in doubt get the metal version as you obviously can’t adjust the tension on the carbon version. For me the carbon version was the ultimate solution for this pair. Very happy with my other two pair just putting the new leather strap on.
May 12, 2024 at 10:15 AM Post #1,122 of 1,229
I've got this one. I believe to be the same as yours.
Yes I noticed there was some DIY involved. I was thinking about ZMF pilot strap, Audeze headband and maybe now the Turbulent lab.
Thank you for the information :)
May 12, 2024 at 2:02 PM Post #1,124 of 1,229
May 12, 2024 at 7:00 PM Post #1,125 of 1,229
Anyone interested in building a killer system under 1000.00 I wrote an addendum to my R7 review uniting the R7 with the Schiit Midgard and HRT HD dac
It is always hugely satifying to find a headphone system that gives more than a taste of what high-end headphone listening is all about. Sounds like you found one incorporating the JM modified Hifiman R7.
