thx a lot , so i will buy itOut of the box
Once you enbale Google on settings, all stock Google languages
Look! MOONDROP's First HiFi Smartphone, MIAD01
- Thread starter MOONDROP
- Tags
- dac miad01 moondrop smartphone
Hope it will have an upgrade in the future.
From what I've read there seem to be incompatibilities with UAPP or am I wrong?
lordearl
- Feb 15, 2007
I'm testing my unit now. It's very impressive. I'll post a detailed commentary/review soon.
In the meantime, if there are any questions or audio scenarios people want me to test please list them here and I will do my best to reply.
Yes, I can confirm it has a long list of languages, more than I could list here.i was thinking , there was only chinese and english support, could you confirm me in settings if others languages are available?
lordearl
- Feb 15, 2007
By incompatibility do you mean it's not working properly in some way or just not working at all?
I'm comparing the MIAD01 to my LG V50 and Sony XPeria 10 V.
Upon installing UAPP on all three devices (I've done a clean install for the purposes of this test):
- LG V50: UAPP detects the hi-res internal DAC and prompts for the user to play music using the hi-res dac.
- Sony XPeria 10 V: UAPP does not detect the hi-res internal DAC and prompts to use the android driver.
- MIAD01: UAPP does not detect the hi-res internal DAC and instead prompts to use the android driver.
This then allows the user to continue playing and it is possible to choose bit-perfect output as well.
I do not know if this is simply because the UAPP developers haven't added these devices to their database of hi-res cabable internal DAC phones.
If anyone has suggestions of other android music player applications which might be worth testing I am happy to carry out these tests as well.
My question arose from the fact that UAPP had often shown problems with devices equipped with a Mediatek processor (recently a friend of mine had found difficulties with a tablet that was equipped with a Mediatek processor), so I have always opted for LG V series smartphones that are equipped with processors Snapdragon and which, over time, have never shown any problems with UAPP. That's all, thanks for the reply.By incompatibility do you mean it's not working properly in some way or just not working at all?
In cases #2 and #3 above we are able to select the following option:
XTF1
- Nov 9, 2014
Moondrop webpage says that the audio output bypasses Android SRC. How does UAPP handle that? Is "Android Driver" the only, but correct hi-res audio output for an Android 13 device where SRC bypass has been implemented?My question arose from the fact that UAPP had often shown problems with devices equipped with a Mediatek processor (recently a friend of mine had found difficulties with a tablet that was equipped with a Mediatek processor), so I have always opted for LG V series smartphones that are equipped with processors Snapdragon and which, over time, have never shown any problems with UAPP. That's all, thanks for the reply.
If this were really the case, it would be the only Android device that can also run Amazon HD in bit perfect to be able to truly appreciate their tracks in maximum definition... will it really be like this??? We await confirmation...Moondrop webpage says that the audio output bypasses Android SRC. How does UAPP handle that? Is "Android Driver" the only, but correct hi-res audio output for an Android 13 device where SRC bypass has been implemented?
lordearl
- Feb 15, 2007
I will test it - please outline the process.
The Amazon HD app on all Android devices is unable to route the data flow directly to the DAC which is therefore resampled by Android and in fact during playback it reads 48kz (Android resampling and consequent loss of bit perfect). If Moondrop managed to bypass this resampling, the Amazon HD app should report the native frequency of the track being played and therefore it would be bit perfect at maximum resolution. That's all.I will test it - please outline the process.
Danx3k
Connect a dongle to the miad that has a display that shows the sample rate, and see what it displays.
masterpfa
- Dec 30, 2014
100% agree, Davy the app developer responds personally and promptly, ahd has for me always provided a solution with, as you have quoted, an individual beta version if required before incorporating it in the official app and updating for all@atechreviews can you try installing UAPP on the phone?
If UAPP reports the HW is not supported - try contacting the (SUPER responsive and nice) UAPP developer. When I got the iBasso DX260 DAP, it was not supported by UAPP... 2 days later - I had a beta version from him that worked like a charm. shortly thereafter, he released an official version WITH added DX260 support! He is a great guy.
lordearl
- Feb 15, 2007
Thanks - I've messaged Davy from USB AUDIO PLAYER PRO with the MIAD01 config files and he wrote back saying that there is No Hires Direct mode.
So I assume there is some resampling happening @MOONDROP ?
On the more positive side, a new firmware has just been released which includes a (very basic) music control panel. There are not many functions, but it is a good start.
- Jan 15, 2015
Hopefully we get a clarification from Davy on what that means...I've messaged Davy from USB AUDIO PLAYER PRO with the MIAD01 config files and he wrote back saying that there is No Hires Direct mode.
When you're playing music with UAPP, what does it display for sample rate etc?
Total: 28 (members: 6, guests: 22)
