elnero
I have the previous 2006 9V version Micro Stack on loan from another local Head-Fier but I've been having some problems with the DAC syncing to my computer via USB using ASIO. Everything seems to work fine initially but after awhile it starts to tick loudly, kind of like a hiccup if you will. The music can still be heard underneath and power down both the computer and the DAC doesn't seem to work all the time either. It should be noted that when this is happening a ticking can still be heard at idle as well (when hooked to the comp).
I mentioned it to the owner who also noted he has had issues with a ticking when trying to get it to work with one of his transports, a DVD player, but other transports he uses he's had no issue with.
Anyone have any ideas what might be causing this?
