It seems not that hard only if you`re sure that you`ll be happy with the result. Oratory1990`s graph shows that treble energy is much higher with perforated pads then original ones. I`m not sure about this swap.I changed them over, it wasn't that hard.
Aeon 2 closed Impressions and Discussion
- Thread starter MattTCG
roskodan
I can certainly see that point.It seems not that hard only if you`re sure that you`ll be happy with the result. Oratory1990`s graph shows that treble energy is much higher with perforated pads then original ones. I`m not sure about this swap.
I swapped for the hybrids, and Oratory's experience is absolutely not what I found. I think they tamed the highs and expanded the soundstage a bit.
By hybrids you mean pads for DCA cans available from Dekoni?I swapped for the hybrids,
At this point I would kindly ask for source of those pads. Original one has just broke at the mounting top point...I swapped for the hybrids,
