Astell & Kern Kann MAX
Mar 10, 2024 at 3:28 PM Post #541 of 550
Updated firmware on my AK Kann Max to 1.22 and LED indicator stays Red when playing master files.
In the past, the LED indicator would turn blue. Now it just stays red. Anyone else experiencing this?
Message has been sent to AK support.
My unit doesn’t do that ? 🤷🏻‍♂️
Mar 11, 2024 at 8:20 AM Post #543 of 550
Can you let me know if you're running Tidal or local files. And if local files, what bit-rate they are? TIA.
Hi. I apologize. I see your point now. I just run local files on SD cards and seldomly use Apple Music. Both red and green show up on the LED wheel no problem. Blue ? Not so much. Even if I’m using or hearing an MQA file.
Mar 11, 2024 at 11:41 AM Post #544 of 550
Is this with the full Tidal app or the embedded app. We have a known issue with the full Tidal app installed via the download tab and are currently working with Tidal on the issue. Will share more info once it is available.
Astell&Kern Stay updated on Astell&Kern at their sponsor profile on Head-Fi.
https://www.facebook.com/astellnkern/ https://twitter.com/astell_kern https://www.instagram.com/astellnkern.official/ https://astellnkern.com astellnkern@astellnkern.com
Mar 11, 2024 at 11:50 AM Post #546 of 550
Has anyone had an issue on the unbalanced 3.5mm output where if you pause a track, after about 5-6 seconds there is a strange static noise for about 3-4seconds? Only happens on the 3.5mm unbalanced output
Apr 4, 2024 at 11:36 AM Post #548 of 550
Good afternoon, there's nothing wrong, I'm sorry, I didn't use Kann for many weeks, I did the update and then the sound was really terrible... But everything is now ok, thanks to the Good Lord, because this Dap is sound that shorter. Thanks
Apr 13, 2024 at 1:24 AM Post #549 of 550
How do you get rid of the “back” button in services? I’ve removed it from the A&K player, but when I go into Spotify and Qobuz it’s in the way. It’s not necessary as one can just swipe up to exit the service.
  • Back
