BlueThunder
What are these like compared to the Sony WM1Z for a set of Audeze 4Z? If I can get one very cheap for home use is it worth picking up or should I stick with the WM1Z for home use?
Thanks. Probably feeding from the WM1Z, single ended output, if that is possible, otherwise using USB from computer.If you can get a reconditioned one, the amp is decent and versatile but the DAC is lacking. I used to own one and I enjoyed it very much. It comes down to how you’re planning on feeding it music.
That’s what I was wondering. I can get it for £200 when buying the 4Z. I wondered if the 4Z would benefit from the extra power (or some future headphone i’m not aware of wanting to buy yet.....)There’s RCA input. I highly recommend avoiding the USB input. I wonder if it would bring much to the table vs the WM1Z, but if you have the funds spare it is a lovely bit of kit so why not treat yourself.
Hi,
Picked up a Dackard a few weeks ago.what gain setting do you guys use for your LCD-2f ?
I Find medium to be more forward than low gain anyone else experience this.
Cheers
