stmiller
Thanks for the settings.Try my eq for the Audeze iSine 10 guys (No CIPHER cable!)
I eq'd it by ear to match the tonality of my Etymotic's (super smooth). Sounds awesome.
Less-precise, parametric EQ:
Preamp: -6.2 dB
Filter 1: ON PK Fc 921 Hz Gain -5.5 dB Q 0.820
Filter 2: ON PK Fc 1474 Hz Gain -4.3 dB Q 2.980
Filter 3: ON PK Fc 2596 Hz Gain 3.9 dB Q 1.250
Filter 4: ON PK Fc 4929 Hz Gain 6.6 dB Q 2.570
Filter 5: ON PK Fc 9000 Hz Gain -2.8 dB Q 1.100
Filter 6: ON PK Fc 3992 Hz Gain 1.9 dB Q 3.890
Filter 7: ON PK Fc 4899 Hz Gain -1.5 dB Q 1.670
Filter 8: ON PK Fc 5863 Hz Gain 0.6 dB Q 5.930
Filter 9: ON PK Fc 4308 Hz Gain -4.7 dB Q 4.700
Filter 10: ON HSC Fc 11000 Hz Gain 5.5 dB Q 1.000
Filter 11: ON PK Fc 3400 Hz Gain 4.6 dB Q 2.600
Filter 12: ON PK Fc 3000 Hz Gain -1.1 dB Q 6.000
Filter 13: ON PK Fc 8000 Hz Gain -2.0 dB Q 1.000
Filter 14: ON PK Fc 7000 Hz Gain 3.4 dB Q 5.000
Filter 15: ON PK Fc 13600 Hz Gain -6.0 dB Q 10.000
Filter 16: ON PK Fc 11000 Hz Gain 5.1 dB Q 1.700
Filter 17: ON PK Fc 9500 Hz Gain -2.0 dB Q 7.000
Highly-precise 130 band graphic EQ:
See attached files for the settings, I also attached a 127 band EQ for Wavelet
By the way, here's how I'm fitting them: Audeze iSINE and LCDi4 Setup Tutorial
I followed the audeze video, im using the medium smooth tips, clear hooks (turned at that angle!), and shallow inserting them like audeze shows
there could be some unit variation shenanigans so it might not sound like mine but this eq that i made sounds WAY better than every other eq ive tried.
How do I enable the 130 band eq on equaliser apo?
