FredA
- Dec 15, 2013
Using an even better ddc, the r2r 11 mkii gives a real taste of high-end. I own the top of the line r7he mkii so i can make the comparison.Well it's been 4 months since I've had the r2r-11mk2 and thought I'd post some more thoughts.
I am still very much enjoying it. I am finding that I really appreciate the dynamics in this thing, while maintaining a very smooth and pleasant tonality to everything. I still stick to my initial assessment that details and staging are just a little bit lacking, but will note that playing with inputs (and oversampling) seem to help a little bit in those regards. Unlike some other DACs I've had, I've yet to notice anything that sounds colored, flavored, weird, off, unpleasant, uncanny, etc. It just sounds good to me ears and don't find myself as curious about other DACs.
But as for negatives, I don't like the USB input on this thing, even with the upgraded USB option I purchased. I have instead been using an inexpensive "DDC" (Douk U2 Pro ~$50) and I much prefer the sound out of this setup. Using of the r2r-11mk2's USB input, the imaging feels more "smeared" and "fatter" while stage seems to flatten out. While this does seem to get a little better using cleaner source gear (computer vs. Pi4b+LPS+Volumio), different USB ports (USB2 vs. USB30), and playing trying certain USB cables, I don't find myself preferring it over the DDC. Using the Douk U2 Pro (especially via optical), things seem to open up just a little bit, breathe better, and sounds a little bit better defined. I'm not finding much loss in the dynamics or change in tonality with either case, either.
For what it's worth, I snapped some pictures of the clocks on the USB board and underneath it to help you better determine if it's worth the upgrade:
These are the clocks that came with my upgraded USB r2r-11mk2 but couldn't really figure out what clocks those are. If I could buy it over again, I would forego the USB upgrade (~$70) and just use the Douk U2 Pro (~$60 IIRC) instead for a USB connection from my sources. Of course, you lose ability to upsample up to 384khz as optical is limited to 24/96 and coax is limited to 24/192 (and can't do 176khz for some reason). I personally don't find myself strongly preferring upsampled stuff to regular NOS.
I also have a WiiM Pro on the way and excited to test that.
One other note: on one occassion, while I was playing around with other amps and whatnot, I had changed the volume on the r2r-11mk2, and about a second or two later heard a loud grinding noise as the volume relays were clicking very quickly and volume shot up to 100. This has happened only once, and I suspect it's because the knob was "straddling" the stepped positions on the knob and possibly shorting or something, causing rapid increase in volume. I was fortunate enough to have been playing a quiet song at the time and didn't damage anything. I have since been more mindful of the volume knob and making sure it's resting in a solid position instead of "in between the steps," and I've not experienced any such issues since.
Finally, I do occasionally want for a little more open and spacious sounding amp. While the amp section on the r2r-11mk2 sounds very full, lush, and smooth, it does feel a little cramped. Compared to Soloist 3xp, Magni Piety, and El Amp II, the stage feels smaller and imaging/separation suffers a little bit. Things have a little more "pushed up against you" feeling off of the r2r-11mk2. On the LCD-X 2021 w/ leather pads, it can feel a little "stuffy" out of this amp, but having swapped to vegan leather pads (which sounds more "neutral"--less warmth and less veiled), it does sound more agreeable to my ears. However, I prefer the HD660s (and DT770s) off of this amp than the aforementioned ones.
So despite all of this, I'm still liking the r2r-11mk2 very much. Now I'm curious what their higher end gear sounds like and find myself wishing I'd gotten an R28 or R1+another amp.
To feed my own r2r11 mkii through usb, i use the usbridge. And a good usb cable. This really helps i feel. Today, i was reflecting on how well cymbals sounded. I was quite impressed.
The upgraded clocks are from Crystek. Using exclusively usb, they are worth the expense.
As for your volume issue, the encoder can easily be replaced if needed. Any qualified technician can do this within 0.5h or less. Your can get the part from Kingwa. I have some spare myself if you want one. I had to replace one on my he9.
