purk
- Sep 26, 2001
Do keep us posted. Hope it works out for you. Make sure to upgrade the PSU to unleash all the sonic potential of the AT-BHA100.
Still loving your amp? I recently add a 4.4 mm input using a genuine Penntaconn jack. Really like the convenient of 4.4 mm input from my Ibasso DX320 Max. This also allows a 4.4 mm loop out if the XLR input is usedSo it arrived today and…it was legit! Was worried being an unknown Chinese 3rd party seller but it’s all here, warranty cards, legit looking stickers, DHL tracking, & a nice thank you card.
I’m not lying when I say I’ve been waiting since MAY to get my hands on one of these. Talked to so many distributors and on wait for months with two of them. And I have to say, I wasn’t disappointed which after my long saga to get one I expected to be. Tried it with the native DAC and my Grado GS3000x and it does exactly what I wanted it to do, it takes another brand’s HP and gives it the typical Audio Technical flavor with juicy female vocals, light bass and a upper midrange twist. Definitely a colored amp versus neutral but I got plenty of those damn things already so I’m happy. I know some people don’t like the native dac with it or think it’s too much of a good thing, but I love it and will definitely experiment with others. It’s got a nice syrupy easy-going sound. Will also look into a better PSU too.
One criticism, I freaked out a bit at first because I used balanced output with a SE input and after pushing the balanced input button the amp started freaking out making popping sounds and flashing colors and I quickly pulled my HP cable, set it back and it stopped. Is this normal? Do I need to use a balanced in to access balanced out? It’s especially silly if true as the DAC has no balanced out.
here is the link again for anyone wanting their last chance to get one new.
https://www.aliexpress.us/item/3256805696705978.html?spm=a2g0o.store_pc_allProduct.8148356.5.245367331Hrkv1&pdp_npi=4@dis!USD!US $1,336.00!US $1,189.04!!!1336.00!1189.04!@210318c317014812780693304e7385!12000034693612742!sh!US!4503426427!&gatewayAdapt=glo2usa
You really need to buy the iFi iPower Elite for your amp. The improvement is immediate and wholesome.
Looking at the photo, looks like the amp can take 2 sets of dual tubes (BAL and SE) and pretty much any 12ax7 compatible tubes.Still loving your amp? I recently add a 4.4 mm input using a genuine Penntaconn jack. Really like the convenient of 4.4 mm input from my Ibasso DX320 Max. This also allows a 4.4 mm loop out if the XLR input is used
Rolling tube isn’t easy here. You need to desolder and solder the tube back. That’s not easy to do at all. No socket for easy tuberolling.Has anyone tried other tubes other the JJs the BHA100 came with? Something less noisy perhaps?
What he said
You can, just have to be really good at DIY installing four tube sockets that’s all.No wonder BHA-100 was discontinued. Until now, I have never heard of a tube amp with non-removable tubes ...
Are you 100% sure it's soldered coz the tubes are sitting on sockets. Man this suck, I mean it's easy enough to R&R socket but why AT went this route is mind boggling.You can, just have to be really good at DIY installing four tube sockets that’s all.
