Thank you for your answer. Do you think there are any improvements in sound quality?1. Yes you can totally.
2. It's similar in all connections
Aune M1P
- Thread starter Scubadevils
pradiptacr7
It's very clean across the board, like crazy clean. The SQ is same and the only thing is different is I think the power outputThank you for your answer. Do you think there are any improvements in sound quality?
Would you buy a SanDisk Extreme or a Kingston Canvas Go! Plus for the M1P?
Hengstenberg
Can the battery be replaced on the M1p?
pradiptacr7
DIY replacement. I mean who can change the modern mobile phone's battery replacement can do itCan the battery be replaced on the M1p?
ColdsnapBry
Has anyone compared this to a Wm1a? Would be curious what's the differences between the two in terms of sound .
DarkWhiteCrow
I have same problem, worst bluetooth audio signal I have ever heard on any device, I tried it on many devices with same result, dont buy BT versionHi Aune.
My m1p has bluetooth connection problems in source mode. hiby wu1, the device that I connected to the player. the connection breaks at a very close distance, somewhere 30-50cm. the connection can also be interrupted even when near the player.
everything works well in sink mode.
and how do I clear the list of bt connections? if there is no such possibility yet, can you add it?
current firmware version is 1.0770.1/0.1/0.0
thanks
Interesting. It’s good to knowI have same problem, worst bluetooth audio signal I have ever heard on any device, I tried it on many devices with same result, dont buy BT version
But only to headphones. Music streams without any problems.I have same problem, worst bluetooth audio signal I have ever heard on any device, I tried it on many devices with same result, dont buy BT version
No even with Bluetooth streamers it doesn't work properly. I agree the Bluetooth is really really poorly implemented and you should stay away from it if you consider buying the M1P.
GeorgeArzi88
will they ever discuss the sound of this device in this thread?
comparing this device with other daps?
what a pity that the forum player.ru dead, people there didn't engage in such useless whining about the lack of streaming, bad bluetooth, and other crap...
first of all, the sound is important to us, at what level it can compete with other daps
That is easy. Other DAPs I had weren’t better than my apple dongle. But the M1P is making every headphone better.will they ever discuss the sound of this device in this thread?
if you read back you'd see many complimentary posts. its the best sounding dap ive had. ive never had high end ones tho. the ones ive had that the aune sounds better than - sony a306, ibasso dx170, cowon plenue d2will they ever discuss the sound of this device in this thread?
btw regarding bluetooth i sometimes use the m1p as source to a bluetooth speaker and ive had no problems, even when the speaker across the room. but thats just me. don't use it any other (bluetooth) way
some reviews herewill they ever discuss the sound of this device in this thread?
https://www.head-fi.org/showcase/aune-m1p.26603/reviews
