AntonNZ
1. budget for one component (dac or amp or headphone)is roughly 2K NZD. MJ sits exactly on it. anything more is way too expensive for me... I can only afford 1 component a calendar year (so it's either a dac or amp or headphone)I would recommend instead of focusing on the subjective aspects of this question and diving straight into to weeds it would be better if you first ask yourself, what's your budget? even if money it's not a question for you, you should put a limit on how much are your willing to spend on a DAC and Amp, specially if it's going to be your first dive into this endless rabbit hole.
Second would be: what headphones do I have or want to get and given that, what kind of power do I need to drive them to their fullest potential, within reason of course.
If this is your first experience with high end personal audio, going straight away for the MJ3 might not be a good idea because you're not going to be able to appreciate what this amp brings to the table, I would suggest you go for something more modest like an magni unity or something like that, and then decide if you want something more and better.
Also you should considere if your needs would be better serve with a desktop solution or a more portable one.
2. headphones are hd6xx, focal celestee and I have plans for hifiman within the budget limits (I will wait for discounts)
3. @ngohw I like rock, metal, indie, post-rock, djent, pop. I don't enjoy the high-frequency sound too much, or at least not when it's pitching, but I like bass. I like stage and separation, or I think that I like it. It is difficult to say, I don't have much to check in order to properly explore.
@Erick Muller , I did think to buy modius + magnius and then upgrade or something similar, but my wife said that I would waste way too much money on incremental upgrades and should buy a good end product from the start. and I agree with her, she is a wise human being who knows me way too well.
