Thank you! What's the autonomy of the surfans? X1 is pretty but I really want physical buttons
Benjie Offical Thread
Podster
Go with the Surfans for Physical buttons. Has great sound for the $, nothing like the Benjie screen but does the job.Thank you! What's the autonomy of the surfans? X1 is pretty but I really want physical buttons
Thank you. It's a shame cause I love the form factory of the benjie
Podster
I love Benjie’s house sound, for what they cost they are Incredible! Before the T6 it was the killer $22 S5Thank you. It's a shame cause I love the form factory of the benjie
So good that you'd turn a blind eye on battery and still get one? I'd love a T6 with the battery of the S5. My current portable set up is a Samsung galaxy with a dragonfly red. It sounds so good but the battery of my phone wouldn't last half day now. That's why I decided to pull the trigger on an Agptek a02 (aka Ruizu x02), but there is a serious problem on the bass region. I guess it depends on the lack of power that also makes this thing work for so many hours. Again, it's a shame because I love the portability and eternal battery life, if only the sound was a tad better... So basically I don't want to take around another device with low battery
Btw the Surfan's 10h of MP3 playing time wouldn't be enough for me. It means more less 6/7 h with flacs, not an improvement over the Benjie T6
lisagorbin
- Nov 19, 2012
Does dongle DACs work with the Benjies and Ruizus?
unaudiophile
Hello!
I've found myself in possession of a Benjie W02 mp3 player. Found that the firmware for Benjie is actually pretty bad, but I've not been able to figure out how to replace it. It's also a bit buggy, it skips the last second of every single track, for some reason. I've emailed both the seller and contacted Benjie customer support for any leads on updating the firmware.
Wonder if anyone else has got their hands on this one and has any experience with it.
Hello, I know this is a bit old but anyone could give me a little help here? I have a Benjie K11 but don't know which fw should I flash because from all those C2 out there, some got me stuck on the Agptek screen and others worked, but not the touch panel. So I ended up flashing again the K11 firmware. Any ideas?I use the Latest C2 Firmware from AGPTEK https://www.agptek.com/blog/agptek-c2-firmware-upgrade-2/ on the K11s and get 50-70 hrs of playtime and the 10-16 hrs with BT 4.2 is awesome ..find no problems with it as its my daily DAP atm..Also remember to reset to factory settings after every flash
*Note..There are 2 versions of C2..The Benjie K11 is the 2018 model ( Latest Version 2)
Wolframe
https://imgur.com/a/cQjeWAE
so uhh. can anyone help confirm that this is actually a Benjie x1? looking around on the internet hasn't helped, the official site doesn't help, and the online shop reviews are worthless so im of half a mind that this is a fake or discontinued player.
Podster
Sure looks just like mine!https://imgur.com/a/cQjeWAE
If it helps this is where I got mine:
https://www.aliexpress.us/item/2255...t_main.76.4f251802aa8988&gatewayAdapt=glo2usa
