What are the best ear tips in terms of tonal Balance and Bass for the Mest MK II?
Best IEM tips?
- Thread starter lilboozy
frkasper
Can you guys recommend 3-4 different tips that are very different? I'm not too concerned about price.
Do you prefer softer or firmer materials? For instance, two antagonistic sets: FiiO HS18 and AZLA Crystal.
Also, try grabbing the FiiO HS19 pack on AliExpress, it is usually less than 15 bucks and there is a good variety in it to get you started.
After purchasing your 10th set, then you can start therapy like the rest of us.
What's a good tip for oily ears? Apart from foam
Search this thread for oily skin. Hope this helps as we're on the same boat on this matter.
Also, do you prefer shallow or deeper insertions?
Hypops
I'm in the same boat. It depends on the weather and climate where you live. I live in a dry desert climate, so my approach is more about just keeping my oily ears clean and dry. But I can imagine in humid and wet climates, you would probably want something firmer and grippier like AZLA tips and Penon Liqueur tips. I also find Spiral Dots and Divinus Velvets stay dry and well sealed. Thinner or more flexible tips like Spinfit and Spring Tips are among the worst for my oily ears (they eventually get too slick and break seal).What's a good tip for oily ears? Apart from foam
bru87tr
- May 21, 2016
Funny, I just got in the HS18 and they sound great. Similar to the HS19 but a bit different fit and a bit different sound. Better depending on the IEM. Both these sets are the best I have found for my ears.Do you prefer softer or firmer materials? For instance, two antagonistic sets: FiiO HS18 and AZLA Crystal.
I found the HS19 for $6.97 and the HS18 for $4.72 on AliExpress. Free shipping too. Best bang for the dollar and you get a big variety.
SomeWhatUniqueUsername
I've been screwing around with ear impression material after buying some off aliexpress. I had an idea to see what would happen if I forced the sound through a small hole.
Doing this makes the bass a kind of in your head, physical type of sound that you can really feel, which is something I haven't heard in any eartip. Too bad it puts a sort of veil on the other frequencies, which was to be expected. This works for a few genres of edm here and there but there's a reason manufacturers don't do this.
I have a feeling this might work very well on the ex1000s.
I'm considering using talcum powder on the tips.I'm in the same boat. It depends on the weather and climate where you live. I live in a dry desert climate, so my approach is more about just keeping my oily ears clean and dry. But I can imagine in humid and wet climates, you would probably want something firmer and grippier like AZLA tips and Penon Liqueur tips. I also find Spiral Dots and Divinus Velvets stay dry and well sealed. Thinner or more flexible tips like Spinfit and Spring Tips are among the worst for my oily ears (they eventually get too slick and break seal).
bru87tr
- May 21, 2016
I really like these, they tamed my artti t10.
https://www.amazon.com/dp/B071Z6J3X...o_cp_apin_dp_ZRPTSMCYZ1EBR9JZBYVR&starsLeft=1
ericx85
- Dec 3, 2014
Any silicone recommendations for the Hype4? I’m using their small sized tips right now but feel like a perfect fit would have been between their small and medium size. The medium tips starts to hurt after an hour or so and itch a lot. The small tips lose their seal when I talk and the items slowly slide out every few minutes.
Any recommendations are much appreciated!
Hypops
Tip fitting is very personal. Nothing for it but to order some in different sizes and see what fits your ears best.Any silicone recommendations for the Hype4? I’m using their small sized tips right now but feel like a perfect fit would have been between their small and medium size. The medium tips starts to hurt after an hour or so and itch a lot. The small tips lose their seal when I talk and the items slowly slide out every few minutes.
Erik1
I just got my Fairphone Fairbuds and the stock silicone eartips are terrible, to put it mildly, and I'm wondering what to pick to replace them? I use them now with a pair of foam TWS tips that I had still lying around but I don't find foam that comfortable.
The (possibly) tricky thing about the Fairbuds is that the nozzles are not round and the tips should be around 7mm high (max) in order to fit into the case. I've attached a few pictures to show what they look like.
What silicone tips would you recommend? Are Azlas an option, for example? I've read good things about them and, contrary to many brands, they are available in Europe.
Does anyone know where to buy replacements of the foam tips that come with the ie300? Also, does anyone know if the tips that come with the ie200 are the same?
dpeterfy32
has anyone heard or used sonicas orza ear tip? If so, what can be known about it?
dpeterfy32
If I push the inear earphones all the way into my ears, the sound image is perfect and the whole deep range is there. however, after half an hour, I feel that it loosens up a bit and comes out of my ears, so the bass will be much less. what do you think is the solution? Should I choose a larger ear tip or do I need ear tips with a more adhesive surface? If I press it all the way into my ear, the isolation and the bass sound are perfect, so there is no lack of bass, which is usually due to the undersized ear tip. the only problem is that it comes out of my ear within half an hour. I'm sure that many of you have had this problem, so I'm waiting for everyone's comments on what solved it.
Thieme
What are the tips that you are using right now? On some of the cheaper tips the umbrella can be a little weak and not having enough outward pressure but it can also be the material. I am a big fan of the Penon Liqueur tips that have a bit of a sticky surface, as well as the Divinus Velvet. They are velvety soft as you might guess from the name but also very sturdy tips. Might want to check those out.If I push the inear earphones all the way into my ears, the sound image is perfect and the whole deep range is there. however, after half an hour, I feel that it loosens up a bit and comes out of my ears, so the bass will be much less. what do you think is the solution? Should I choose a larger ear tip or do I need ear tips with a more adhesive surface? If I press it all the way into my ear, the isolation and the bass sound are perfect, so there is no lack of bass, which is usually due to the undersized ear tip. the only problem is that it comes out of my ear within half an hour. I'm sure that many of you have had this problem, so I'm waiting for everyone's comments on what solved it.
dpeterfy32
Spinfit w1 smallWhat are the tips that you are using right now? On some of the cheaper tips the umbrella can be a little weak and not having enough outward pressure but it can also be the material. I am a big fan of the Penon Liqueur tips that have a bit of a sticky surface, as well as the Divinus Velvet. They are velvety soft as you might guess from the name but also very sturdy tips. Might want to check those out.
Total: 6 (members: 1, guests: 5)
