MROOD
So I bought a Facal Eligia headphones
They come with a 1.2m cable which i think is a general length
So I need a longer cable, ideally 2m in length
Ive checked on eBay and the cheapest one I found in the UK was £70 or $80
Does anyone know if I can get a general cheaper cable from anywhere? say around £35 or $40
Also I've noticed that you can connect balanced 4.4mm cable to the headphones, I thought that balanced cables are for balanced headphones, as the Elegia is not balanced? as the wrong cable connected to a non balanced headphpones can blow the drivers?
I have a DAP that has a 4.4mm balanced port, so can the elegia connect to 3.5mm standard and 4.4mm balanced?
