dpump
- Jun 23, 2001
What are 2 tubes on the left side? Maybe voltage regulators? And the 2 input tubes? 12AU7 or something else?
I think they could be power supply rectifiers and maybe are the RCA 22DE4, which is the one used on the HA300 for the same purpose.What are 2 tubes on the left side? Maybe voltage regulators? And the 2 input tubes? 12AU7 or something else?
It looks beautiful.
Very curious to see if this might also be used an amp, or a preamp...
Stay updated on Cayin at their sponsor profile on Head-Fi.
My PrimaLuna Dialogue Premium HP has the feature to change between Triode and Ultralinear on the fly. It is an integrated amp with headphones output same as the speakers output just reducing the power to fit headphones.
I actually use it exclusively for headphones.
It can also un EL34, EL77, KT88, KT120 and KT150.
Stay updated on Moon Audio at their sponsor profile on Head-Fi.
Thanks Andy. Shame about the speaker outs but I can see the strong family resemblance with the HA300.I don't have a photo of the rear panel, but the following drawing should serve the purpose. There is no speaker output in the HA-6A.
From the PrimaLuna website:
HEADPHONE AMPLIFIER
One of the best headphone amps in the world. And the only amp that lets you listen with either the warmth of Triode or the wide-bandwidth of Ultra-linear operation at the push of a button! Most tube integrated amps and preamps use a solid state op-amp chip for running headphones. Stand alone tube headphone amps will vary in quality like any other tube amp. Headphones are simply small speakers that require less power. Some amps will use smaller output tubes that groan to have enough dissipation to run power-hungry planar headphones. Other brands, including those costing $5,000 or more like Mal Valve, will use larger output tubes, then use a voltage divider network to drop the power down to an acceptable level for headphones. This is how PrimaLuna designed the HP. We simply took advantage of the fact that this is the best tube integrated amplifier. Now you don't have to pay for a separate state of the art headphone amp. The HP is the favorite of owners who use everything from Audeze to Hifiman to Sennheiser!
and as I said, one can clearly hear the difference through the headphones when switching between Triode and Ultralinera.
