Well, it's really hard to test the Cayin 8 against the Ferrum ERCO 2 since switching between them is not a seamless process - going to do my best. Interestingly, with the Cayin 8 on high gain and the ERCO 2 on high, they share approximately the same volume position with a comfortable listening level, around 1130 o'clock. I'm comparing them both in solid-state mode to make it fair using my Susvara, most recent revision. I get more mid-bass from the ERCO 2, but more sub-bass from the Cayin 8. The mid-bass on the Cayin 8 is more forward than the ERCO 2. These have two completely different DAC chips and setups, but surprisingly they sound somewhat comparable. The vocals on my mids test song are forward and extremely clear on the Cayin 8. The highs are more pronounced on the ERCO 2 and the vocals are slightly more distant. Female vocals are also more prominent on the Cayin 8. Distorted guitars on the ERCO 2 sound sick and the high-hats in the background come across cleanly with some excellent vocal reproduction. Guitars are less pronounced on the Cayin 8 as are the high-hats. Using a song to specifically test for sibilance and highs, the Cayin 8 is pretty sharp on this song, which is pretty typical, and the cymbals are a little recessed in the background. The cymbals on the ERCO 2 are less recessed, and the sibilance is still there, but less sharp. It's an overall better highs presentation on the ERCO 2 for my preference. The soundstage and imaging on the CAYIN 8 is excellent, putting the instruments exactly where they should be and providing a large soundstage without feeling distant. The ERCO 2 is pretty similar here with more pronounced guitars, but with a smaller soundstage - imaging remains on par.
These systems are pretty close in price and perform pretty close as well. The big different here is that the ERCO 2 is an all-in-one box, which is truly impressive how it performs for its size. It also doesn't have a tube option and the Cayin 8 looks significantly nicer. Additionally, the ERCO 2 requires an adapter to use a 4-pin XLR cable, while the CAYIN 8 does not. The filters on the Cayin also provide a little more tuning ability. So, if you need a simple AIO box, the ERCO 2 is pretty great and provides similar power to the Cayin 8. If you are cool with the 2-box (or 3) system, the Cayin 8 is very good. Now I just need to decide which one to keep...or maybe I'll keep the RME - choices, choices, choices. Leaning towards the Cayin 8 at the moment.
