Cayin N30LE DAP: A Transformative Milestone (30th Anniv. Limited Edition)
Apr 15, 2024 at 11:06 PM Post #2,926 of 2,940
Maybe N30BLE refers to re-Biased version of N30LE?
Searching the thread, there's only one forum member used BLE. Most owners have typed out "re-biased"
Apr 15, 2024 at 11:09 PM Post #2,927 of 2,940
I had a guy offer to sell me one, and he referred to it as a "BLE". My search-fu was weak, and I also only found that reference. Given the thread is pretty long, I thought I'd ask assuming I'd missed something. Thanks all.
Apr 16, 2024 at 2:25 AM Post #2,928 of 2,940
Well there is no official "BLE" Version so be careful if that offer is from a new/unknown account
Apr 23, 2024 at 11:03 PM Post #2,930 of 2,940
At the firmware 1.4 I noticed that when disconnected headphones with Jack 4.4 mm, the tray menu continues to be show connection bal. 4.4 mm, it’s mean that output still from bal 4.4 jack and I cannot to use mini jack 3.5. Restarts or other actions not give positive effect. I can use only balance output 4.4 mm. Now I returned to the firmware 1.3, while all normal, I’m testing now, but still connection - disconnection is ok. Is it possible to update firmware regarding 4.4/3.5 mm connection.
Apr 24, 2024 at 2:50 AM Post #2,931 of 2,940
The v1.4 firmware does not involve any change that affected the detection circuit of the phone jacks, so this sounds very strange indeed. Besides v1.4 firmware was released back on Jan 17, if it messed up with daily functions such as phone jack detection, it probably had caused some troubles already.
I suggest you clean the connectors (HERE and HERE), and give v1.4 firmware another try. Please keep us informed :beerchug:
http://en.cayin.cn/
Apr 24, 2024 at 3:27 AM Post #2,932 of 2,940
Ok. I will try to clean. But any way there are no problems with fw 1.3.
Ps. I used fw 1.3 and 1.4 several times with the same effect.
Anyway, after disconnected 4.4 jack, change time connection may be different, 5 sec., 10 sec. 15 sec.
Apr 25, 2024 at 2:22 AM Post #2,933 of 2,940
I received a PM asking if there is any mobile phone screen protector is closed enough to use it with N30LE, so I asked for the screen protector CAD file and retrieved the dimensions page for your reference.
http://en.cayin.cn/
Apr 26, 2024 at 8:57 AM Post #2,934 of 2,940
@Andykong no updates for this flagship DAP since Jan, which is slightly disappointing.
Most of all, there seems to continue to be no movement on that Roon certification process, which is the thing I am missing most.
Apr 26, 2024 at 9:51 PM Post #2,935 of 2,940
Good day.
Contractors clean carried out.
Fw 1.3. On the first day connection - disconnection 4.4 jack without problems immediately. On the second day disconnection time delay increased up to one minute.
At the fw 1.4 situation the same, first day disconnection - ok, at the second day I wait one minute. According my experience, tomorrow I can’t to disconnect 4.4 jack.
May 3, 2024 at 10:01 AM Post #2,937 of 2,940
May 3, 2024 at 1:09 PM Post #2,938 of 2,940
Congratulations 🎂👌👍
Much appreciated! My next purchase will be a closed back headphone to pair with this bad boy... Looking forward to Canjam London.
Btw, can anyone explain the dsd compensation on the N30LE? I see a toggle, but my N8ii had a scale you could set between -6 through+12... What would the DSD compensation on the N30LE equate to?
I always keep it turned off anyway, but I'm just curious.
Thanks in advance
May 9, 2024 at 10:03 PM Post #2,940 of 2,940
N30LE Firmware v1.5 Update
  • Add new PEQ functions under the Audio Setting menu
  • Other bug fixes and optimizations.
Announcement Link: https://en.cayin.cn/drive/9/18/640.html
Firmware Update
Cayin will release firmware updates to enhance and optimize N30LE as deemed required. Users can update the firmware through OTA or local updates. To manually download the firmware, please visit the SUPPORT center on our official website and please make sure you select “Personal Audio” on this page.
Attention
  • Please make sure the DAP has not less than 30% battery power, otherwise please charge up the player before you proceed to a firmware update.
  • Please make sure your DAP has more than 2GB of storage before the firmware update.
  • Do not operate the device during a firmware update.
  • During a firmware update, the device will turn off and reboot automatically. If the device does not reboot 3 minutes after being turned off, please press and hold the POWER BUTTON for 3 seconds to boot up the device, the device will resume the firmware update process.
  • Please delete the firmware file from the TF card or internal storage after you have completed the firmware update process.
OTA Update Procedures
  • Connect the N30LE to the internet via Wi-Fi.
  • Enter the Settings menu, and then proceed to “System” -> “System Update”.
  • Press “check version”, and the system will check for new firmware.
  • Press “Download” when your DAP detects a new firmware. The N30LE operating system will download the new firmware as instructed.
  • Press “Install now” after the firmware is successfully downloaded.
  • Press “OK” at the pop-up dialogue, and the system will proceed to install the new firmware.
Local Update Procedures
  • Download the latest firmware update package from the SUPPORT center of Cayin’s official website, you should receive a compressed file as cayin_N30LE_XXXX.zip which will be used for the N30LE firmware update.
  • DO NOT decompress the zip file.
  • Copy the firmware file into the root directory of the N30LE internal memory or the root directory of the TF card, and insert the TF card into N30LE before you proceed to the next step.
  • Press the “┇” icon on the top right corner of the screen.
  • Select “Local updates” in the pop-up menu.
  • Proceed to the directory where the firmware file is located, and then select the firmware file.
  • Press “INSTALL NOW”.
http://en.cayin.cn/
  • Back
