Cayin N3Ultra: an Entry-level Portable DAP that Delivers a Complete Vacuum Tube Audio Experience
Apr 21, 2024 at 10:05 PM Post #526 of 657
Apr 22, 2024 at 10:48 AM Post #527 of 657
Hi,
Pressing the power button for a few seconds to bring up the power of screen and turn it of by that does not completely turn of the dap is that correct?
I used that method and a few days later came to use the dap and battery was completely flat. I know there is a power of method where you hold the power button for 15 seconds but that surely is not the only way to completely power it down?
Apr 22, 2024 at 10:52 AM Post #528 of 657
Hi,
A single power button press will turn the display on/off. When you hold it down for a few seconds, you will get a screen notification with the Power off or Restart options.
Apr 22, 2024 at 11:08 AM Post #529 of 657
Hi, yes that is what I pressed that little power of screen appears after holding for a few seconds then I selected the power of button screen to power of.
When I came to use it a few days later it was completely flat couldn't turn it on so had to charge it.
Apr 22, 2024 at 12:26 PM Post #530 of 657
many DAPs do have some background current leakage even when it is shut down, causing a battery drain. However, I'm not sure if what you are experiencing is normal; do you remember at what battery level did you left it off before shutting it down? Charge it up to 100% again, shut it down, and wait a few days. I will do the same when I get to it, for consistency. Also, Andy can probably comment on your test results. I didn't see battery standby time listed in the spec.
Apr 22, 2024 at 12:54 PM Post #531 of 657
I'm shutting down my unit at 60% right now. Let's see how many % left tomorrow morning after i wake up.
edit: it has been 20hours since i turned off my unit at 60% battery and i'm happy to report that my unit boots up with still 60% battery left.
Apr 22, 2024 at 12:59 PM Post #532 of 657
Maybe you've missed the power off icon. I did notice on some occasions that the player does not shut down automatically even after a long period of inactivity. Maybe it wasn't off.
I'm constantly touching the wrong icon with the N3U :).
I haven't noticed any noticeable battery loss with the player turned off over the course of 20 hrs. And I haven't left it untouched for longer than that.
Apr 22, 2024 at 1:08 PM Post #533 of 657
It was around 70% when I shut it down.
Apr 23, 2024 at 2:21 AM Post #534 of 657
I spent 1.5 weeks listening the N3ultra.
I decided to return my unit to the dealer.
There are too many bugs and QC issues.
However, the sound quality is good and I like it.
Hope, Cayin team will improve the software and hardware QC in next gen.
Apr 23, 2024 at 3:20 AM Post #537 of 657
1. Battery flopping around while shaking
2. Light leaks on the edge of the screen
I have uploaded the video in this link. Check it out.
https://drive.google.com/drive/folders/10Vktm3WSlKSc0HKFA8jJeMCfG6D_g73m?usp=share_link
Yea, your unit definitely have issues.
Mine does not have any issue.
Nothing rattles or feels lose no matter how hard I shake it (I mean nothing extreme of course).
My unit also does not have any light leaks from the edge of the screen like yours.
Apr 23, 2024 at 3:32 AM Post #539 of 657
Something rattling inside is obviously not good.
I have the light leak, but tbh, I'm not to bothered. I only noticed it when lying in bed, you know, dark room, strange angle, all the right conditions. In normal use it isn't noticeable.
Apr 23, 2024 at 6:31 AM Post #540 of 657
Is there a way to configure the button below the screen to wake-up the screen instead of pushing the power button?
Do you mean the circular "Home" button? That does not have the wake-up function, a limitation of circuitry.
http://en.cayin.cn/
