Link, please?I got some of these little plugs. They come with cables that are magnetic and the jump right onto the plug. No more messing with the stupid micro USB.
Chord Mojo 2 Thread ___ [product released January 31, 2022 -- starting on page 95 of thread]
- Thread starter TheEldestBoy
Jerome Howard
https://www.amazon.com/dp/B09CL33LL3?psc=1&ref=ppx_yo2ov_dt_b_product_details
There are different brands, but these are what I got. Comes with plugs for USB-C and Apple Lightning. They were great.
Thank you, just found it!https://www.amazon.com/dp/B09CL33LL3?psc=1&ref=ppx_yo2ov_dt_b_product_details
Jerome Howard
I use the USB-C plugs on my wireless headphones. I just hold the cord close, and it snaps on. Easy. No fiddling.
Question, did anyone test Poly with Google/Android TV? Does it work?
Chudalicious
- Jun 23, 2009
just got a mojo2 and running out of my MacBook on Tidal. For some reason, it always shows playback at 44.1 (red light) no matter the quality. I see MAX and have Tidal playback set to max. They are NOT MQA tracks but say FLAC so any help is appreciated. Kinda stuck!
Have you turned on 'Exclusive Mode' from the 'other settings' option for the Mojo under the speaker looking tab at the lower right ?
Chudalicious
- Jun 23, 2009
I had NOT!!! I didn’t even know about that setting. THAnK YOU!!!Have you turned on 'Exclusive Mode' from the 'other settings' option for the Mojo under the speaker looking tab at the lower right ?
One other consideration after testing this before commenting.
I suspect you need the Mojo drivers installed to get the other setting menu.
I don't have them on my old Mac and don't get the other settings menu option but I do on my PC and do get the menu option.
Chudalicious
- Jun 23, 2009
It actually did show. Just took a few moment to pop up once USB’d in and all is well. Thank you again @BS5711 for the tip. Drove me crazy!One other consideration after testing this before commenting.
Excellent, nothing better than solving an annoying head scratcher of a computer problem easily
Hypops
Had this exact problem after Tidal’s recent changes. Totally forgot that this ended up being the solution.One other consideration after testing this before commenting.
Got Intona 7055-C today. It seems to democratize cables a lot. It feels like finally Mojo can show what it's made of with 7xx/32 PGGB files. It was quite amazing already earlier, but there was some kind of instability in sound and with bad cables not only did I have constant blasts of white noise, but also some kind of irritation in ears. Now sound is super clean and got a lot of more depth. Also cables that caused blasts don't seem to do it, at least immediately. Interesting weekend ahead
ekfc63
Apologies if this has been covered before, but my Mojo 2 charging light has started flashing red and won’t take a charge. My unit is out of warranty so I can replace the battery myself. Does anyone know where the battery can be purchased?
rwelles
If you haven't already tried this, leave it plugged in for at least 24 hours. Otherwise contact The Sound Organisation (support@soundorg.com) if you're in the US/Canada.Apologies if this has been covered before, but my Mojo 2 charging light has started flashing red and won’t take a charge. My unit is out of warranty so I can replace the battery myself. Does anyone know where the battery can be purchased?
