Continental Dual Mono Tube Rolling Thread
Nov 11, 2017 at 3:34 AM Post #137 of 162
New tubes for my CDM, soldered to pcb in Japan especially for me. More about it when I find the time.
Nov 11, 2017 at 6:27 AM Post #139 of 162
What brand/type are these?
They´re vintage Sonotones. They have an extremely well transparency and resolution, with excellent treble and mids. Much better than the Sonotone tubes from ALO. They´re ultra rare, but sound absolutely sublime, though I have other vintage tubes, which sound better still...... :smirk:
Nov 14, 2017 at 2:45 AM Post #141 of 162
A little look into my private vintage tubes collection. 13 pairs and counting.
Dec 30, 2017 at 6:16 PM Post #144 of 162
WOW, I have had my CDM for over a year and never changed the tubes before last week. I replaced the stock with the 5719 and it does run cooler and longer. Where can we find the rare tubes for this gem?
Jun 16, 2019 at 1:34 AM Post #145 of 162
Ken,
Will you be working on Russian tube 6n16
The Continental Dual Mono (CDM) was specifically designed to allow for relatively easy tube rolling of the sub-miniature dual triode tubes used in the CDM. This is achieved by our implementation of a 8 pin tube PCB and 8 pin header on the CDM. ALO audio will have available unpopulated CDM tube boards for use for tube rolling as well as sell populated CDM tube boards ready to be used with your CDM. The stock CDM will sell with a NOS Phillips 6111wa tubes we purchased new in box with 1988 dates on them. There were large quantities of pencil tubes produced and can still be bought which is why we wanted to utilize our 8 pin header and PCB solution for tube rolling. We hope this feature of removable tubes for your CDM will make the product more enjoyable and fun for all.
In the coming days we will test and post compatibility but we are confident these tubes will work.
6112
6021
6832
6BF7
6247
6AD4
5719
5718
6947
6948
So far we have only confirmed the 6112, 6021 and 6832 work ok. I will also post a short instructional video on disassembly and proper handling of the CDM. All one needs is a 1.5mm torx driver that we supply with every CDM.
Below are some images of the 8 pin header and ALO 8 pin sub-miniature PCB.
Here we have 2 unpopulated 8 pin header tube PCBs
various 8 pin tubes, on the far right is the 6832, on the left is the tube we will include stock with the CDM a Philips 6111WA.
How to install, simply load the tube with pin #1 into the square shaped hole on the PCB in the orientation you see above.
Solder and trim, be sure to mount the tube all the way on to the PCB straight and level.
Next you remove the existing tube simply by pulling off the 8 pin header and then lining the new tube up to install on to the 8 pin header.
Thats it your all set. Note the tubes will come installed with a small piece of 3M VHB tape which helps the tube stay level and straight. This can easily be replaced.
Please stay tuned for more information.
Thank you
Ken
Sep 19, 2019 at 10:58 AM Post #147 of 162
is cdm still a good tube balanced amp in 2019? what is the limited version different to the non limited? seems alo is not offering options tubes with pcb.
also, is the pcb selling as part so i can solder other tubes? or i have to unsolder the bundled and solder another one on.
please kindly advise!
Nov 17, 2019 at 11:28 AM Post #149 of 162
I have same questions as well, and wonder if this amp still a good buy ?
I owned this amp and regret selling it. Outside of ALO, I don't see any portable tube options in the same league but lots of SS options such as my WA11 which sounds really good as well as iFi Micro BL. There is the portable tube amp, WA8 but it costs $1,800!
Nov 17, 2019 at 12:40 PM Post #150 of 162
Sort of depends on your use case. It’s a great amp, but it’s too big for true portable use, and it runs hot. The DAC section has an extremely smooth tuning that some love and some hate. And it’s not necessarily the best choice for either super sensitive hiss-prone IEMs or hard to drive headphones.
