BBEG
- Nov 27, 2011
Although my budget prebuilt computer has had some hefty upgrades, it still uses the original Gigabyte M68MT-S2P motherboard. It's a good, reliable board, but is very limiting for ATX: one PCI-E x16, one PCI-E x1, and one PCI slot each. My GPU uses MSI's TFII cooling solution, which means two intake fans. A sound card plugged into my PCI-E x1 slot would block at least one of the two fans.
I know several companies make riser cables that allow more flexibility in positioning. Would such a cable impact a sound card in any negative way?
