Thorsten Loesch
Member of the Trade: Studio RaumklanG, Studio Cocktail
Hi,
> You are missing that the LM317 in the device I referenced allows the voltage output to be adjustable.
No, I'm not. But you don't noisy LED's on the ADJ pin to adjust the voltage.
> We've found that voltage variances in the many PC/laptop/USB-cables can be significant when attempting
> to regulate prior to a USB-powered DAC.
Yes, cables can be an issue, especially where there is higher current draw.
The correct route of action, if we consider a need to compensate should be peruse the USB.org specifications for USB cables and to then create a circuit with negative impedance that compensates cable resistance. All modern battery charger IC's include such a function.
> A 7805 regulator can't create voltage greater than what it is supplied.
Neither can a LM317.
I did not suggest to use the 7805 in my post, where I discussed modifying a commercial OTS ultra cheap (13 USD) linear power supply.
I suggested that given the final intended setup with a super capcitor bank after the 7805, there was little point to make an effort to replace it with something else.
Finally, if I want 5.25V from a 7805, I put a 1A low voltage schottky diode into the ground pin connection. Or I could use a 3.3 Ohm resistor in the ground line and a 62...68 Ohm resistor between output and ground pin.
Not that I would do that in a ground up design, be it LM317 or LM7805 etc.
> The USB standards themselves allows for voltages as low as 4.4VDC, even from "quality" hubs. The problem is that most quality DACs have onboard
> regulators for 4.75V analog and 3.3V digital, among other things. They're all designed and produced in theory for 5VDC supplies in mind, but potentially
> not very tolerant to lesser voltages for best noise-reduction performance.
That's up to the DAC designer.
I tend to use a > 1MHz switcher (with lower audio band noise than a LM317 and the ability to work down to 3V input) to produce 5.7V for internal use. It's actually part of a single chip power SOC marketed for digital cameras that includes a number of liner and switching regulators on board.
The 5.7V is just enough shy of the 5.8V rating of a specific IC I frequently use directly from this rail to guarantee worst case tolerances do not exceed this rating. That IC is a charge Pump that produces a negative line and also operates around 1MHz, so I can run the headphone amplifier on +/-5.7V and have enough overhaed to regulate the rail down to 5V for a 5V DAC using a low noise circuit.
Of course, such an approach is often beyond what can be done DIY.
> Anyway, a case can be made that a slightly higher USB voltage from the power supply will result in less overall system noise. The LM317 gives you that flexibility.
The LM317 gives that flexibility with less noise if the LED's are replaced by a resistor and capacitor as suggested in the datasheet. Moreover, it is not specifically a function of the LM317 that cannot be achieved with any other circuit.
So it is not enough of a reason to use the LM317 and then specifically in a way that adds noise over the datasheet application.
Thor
Thor
