I have some nat king cole albums in different productions, some are totally awfull. I even have some vinyls, that sound insane amazing, but the digital recording (of that specific album, various of them), my life… a total utter remaster f*ck upLogically that has to be the reason. Going to find the other cd sometime this week. Just another dimension of ripping cd’s. I remembered that there used to be some sort of loudness wars or something to that effect in the days of cd’s being produced.
Eversolo DMP-A6 Network Streamer/DAC
- Thread starter PopZeus
tylerindianapolis
Yep different production's. The one on the left sounds better. If I was one of those salesmen I could put the left one on a more expensive setup and the one on the right on a lesser expensive setup and have one listen to the difference of the setups or have two setups with a more expensive usb cable and claim it was the cable.I have some nat king cole albums in different productions, some are totally awfull. I even have some vinyls, that sound insane amazing, but the digital recording (of that specific album, various of them), my life… a total utter remaster f*ck up
I am sure you are wise enough to know but many would not.
Native Apple Music plus PEQ is a pretty killer combo for my system but I’d prefer to use my DAC rather than the integrated DAC. I’ve tried to skim this thread (hopefully this isn’t the fifteenth time for this question) and the A6 manual on Eversolo’s website predates PEQ’s addition:
Can you use PEQ over the digital outputs on the A6? The A8 manual specifically mentions PEQ works only with analog outs, assuming the A6 is the same.
EQ works fine to my A6 digital outputs.Native Apple Music plus PEQ is a pretty killer combo for my system but I’d prefer to use my DAC rather than the integrated DAC. I’ve tried to skim this thread (hopefully this isn’t the fifteenth time for this question) and the A6 manual on Eversolo’s website predates PEQ’s addition:
JjB067
Yes on the A6 the DSP EQ functions apply to any of the outputs be they digital or analog, in contrast to the A8 where as you say they can only be heard via the analog outputs.Native Apple Music plus PEQ is a pretty killer combo for my system but I’d prefer to use my DAC rather than the integrated DAC. I’ve tried to skim this thread (hopefully this isn’t the fifteenth time for this question) and the A6 manual on Eversolo’s website predates PEQ’s addition:
You can do that with the A8 as well, I hate EQ in any form, but that is another discussionYes on the A6 the DSP EQ functions apply to any of the outputs be they digital or analog, in contrast to the A8 where as you say they can only be heard via the analog outputs.
Well, sometimes for speakers it is a good way-out from boomyness and darkness, something like mild room correction, if you know what are you doing. I also hate doing DSP in digital since often it messes with soundstage and do not use the A6 EQ; but I use a 7band tube pre-amp and click, click, one-two notches up and down, are fully ok and beneficial often, and fit different moods.You can do that with the A8 as well, I hate EQ in any form, but that is another discussion
Smoothstereo
Anyone know if A6 or A8 has volume balance control now thru new firmware updates? Also what is the highest upsample rate in pcm and dsd it can do ? Thanks.
skhan007
I was about to ask a question about the ability to manually change the sample rate of my local FLAC and ALAC files. It sounds like this is possible up to 192 kHz.About the upsampling options on the Eversolo DMP-A6. I couldn't get anything to work in this regard until the Eversolo Audio Engine setting is set to OFF. Then the different sampling rate options work as they should from original sampling rate to 192 kHz. This is using the internal music player playing local PCM 2ch FLAC files, I am not sure what happens if you use streaming services as the source. The digital outputs if you have enabled them reflect the new sampling rate, I have checked the SPDIF coax and USB Audio OUT, presumably HDMI follows this as well. One thing to note that if you are currently actively playing a track and change the sampling rate in the A6 settings, it will not take effect until the next track in the play queue is started. So maybe halt any music playback, change the rate, then start music playback again to avoid any confusion. Need to listen a lot more before offering any opinion on whether upsampling on this device alters the sound quality.
Correct.I was about to ask a question about the ability to manually change the sample rate of my local FLAC and ALAC files. It sounds like this is possible up to 192 kHz.
martas38
It's possible, but Eversolo doesn't do it as well as Audirvana or HQPlayer. No parameters can be set, only the sample rate.Correct.
JjB067
There is a volume balance option now on the A6 and I assume also on the A8. Upsampling on the A6 is possible up to 192 kHz PCM, you need to turn the Eversolo original sample feature OFF to get this to work.Anyone know if A6 or A8 has volume balance control now thru new firmware updates? Also what is the highest upsample rate in pcm and dsd it can do ? Thanks.
Smoothstereo
Thanks. That's awesome news, I like the volume balance feature. Any word if A6 or A8 will be able to upsample up to 384khz PCM in future firmware?There is a volume balance option now on the A6 and I assume also on the A8. Upsampling on the A6 is possible up to 192 kHz PCM, you need to turn the Eversolo original sample feature OFF to get this to work.
JjB067
Not that I am aware of.Thanks. That's awesome news, I like the volume balance feature. Any word if A6 or A8 will be able to upsample up to 384khz PCM in future firmware?
tylerindianapolis
I switched up a little bit. I purchased a decent quality spdif coaxial to go from the a6 and feed the ef499 and have decent quality cables from 499 to the Nitsch Maximus (RCA) and xlr to the Schiit Midgard.
I disconnected the Amazon Music in hires and switched to Tidal since it is the same price now.
Ripped CD’s sound comparable to MQA but with this setup if I listen to a MQA song and the same album song (sure I don’t know some stuff) but I can hear the singer breathing now.
The Spdif I caved and purchased is an audio quest black carbon .75 meter..
I can hear a difference with usb and spdif. Spdif sounds better and I am still not sold audio quest black carbon has more magical power than another 75 ohm cable but it looks good. that was a splurge though.
Total: 3 (members: 1, guests: 2)
