I don’t find harshness and sibilance, even with my Susvara, so I believe the Elite will likely be even less harsh.
I started with the Erco and it is now acting as my dedicated DAC feeding the Oor now!
Also, the Erco vs the Oor isn’t a fair comparisons. They are similar, but the difference impact and power output of the Oor is pretty significant. The Erco is like a little sibling to the Oor. Both have controlled and defined bass, but the Oor improves on the sound in both articulation and impact.
Mind you, my experience is solely with my own headphones and I have no experience how much of a difference there is for the Meze Elite. If you want to check out the Erco, I highly recommend you do. If you feel like you need “more” which you may very well not, you can always add the Oor into the chain!
