[FiiO BTR15/BTR5 2021/BTR5]Bluetooth DAC and Headphone Amplifier Discussion & Impressions Thread
Nov 1, 2019 at 4:23 AM Thread Starter Post #1 of 3,686
FiiO
Sponsor: FiiO
Guangzhou,China
1. High Performance DAC ES9218P*2
2. Flagship Bluetooth chip CSR8675
3. FPGA clock management,dual independent crystal oscillators
4. Bluetooth 5.0 with full format support
5. Independent control chip XMOS XUF208
6. USB DAC supporting up to 384kHz/DSD256 native
7. Double-sided 2.5D glass with OLED display
8. 3.5mm+2.5mm headphone outputs
9. Intelligent control with FiiO Music app
10. One-touch NFC pairing
Nov 1, 2019 at 9:04 PM Post #4 of 3,686
Available now? Taobao?
Nov 1, 2019 at 10:07 PM Post #5 of 3,686
Is this MFi?
No MFi on the USB DAC, and you don't need MFi for Bluetooth since it is a common standard.
First batch already sold out in China, I believe the second batch comes later this month.
This is an excellent pairing - BTR5 with Smabat M1 Pro in balanced.
Nov 2, 2019 at 5:38 PM Post #6 of 3,686
Also enjoying the M1 Pro, but finding them a little limited in volume output and ability to render deep bass sounds (dub). Besides that, lovely sounding buds. :ksc75smile:
Nov 4, 2019 at 2:32 AM Post #9 of 3,686
Nov 4, 2019 at 3:13 AM Post #10 of 3,686
Is this MFi?
Dear friend,
No. The BTR5 does not have MFI. But theoretically, if you would like to use the BTR5 as the USB DAC, you could connect the ios device with the BTR5 via the Apple Camera Connection Kit (CCK) ,with BTR5 charge option in off status.
Best regards
Nov 4, 2019 at 5:29 AM Post #12 of 3,686
@FiiO is it possible for you to post here when there's a firmware update or support app update?
I am very keen to get the on board equaliser working on LDAC and USB and hoping you will release a firmware update soon which fixes these issues.
I am currently on firmware version v1.0.1 and support app version 1.0
Nov 4, 2019 at 5:57 AM Post #13 of 3,686
@FiiO
There is nothing to fix. The device probably doesn't have the processing power to EQ high bit rate data streams like LDAC
Nov 4, 2019 at 6:05 AM Post #14 of 3,686
hmm, if that's true I might return it.
They should make that clear on their product page, as at the moment they advertise it as having an equaliser, they should make it clear it doesn't work on LDAC or when using as an USB DAC.
The radsone es100 has no problem with this on LDAC, I would think the BTR5 has equal or higher processing power.
Would love an official statement from @FiiO on this though.
Nov 4, 2019 at 6:14 AM Post #15 of 3,686
The Equalizer only works when streaming in the SBC, AAC, aptX, aptX-HD and HWA(48kHz or lower) codec. It does not work for the LDAC codec. And for HWA 96kHz, it's suggested to turn off EQ, otherwise there might be noise.
BTR3 firmware info
