[FiiO BTR7] Portable Bluetooth Amplifier, Color IPS display,High-performance DAC ES9219C*2,THX AAA-28*2 amps,3.5+4.4mm outputs,One-click “dongle” mode
Mar 4, 2024 at 9:19 PM Post #2,026 of 2,083
You guys I am so dumb. After a quick trip to the bathroom, I had my Fiio BTR7 in my hoody pocket and it slipped out as I leaned down to flush the toilet. :O
Ouch. You can try putting into a sealed container of uncooked rice overnight…
Mar 5, 2024 at 1:43 AM Post #2,029 of 2,083
This happened on the BTR5 as well. My friend's iPhone 14 Pro would not recognize the BTR5 no matter what. We didn't try the BTR7.
Dear friend,
You are connecting the BTR5 to the iPhone 14 Pro via Bluetooth or USB?
1. If you are connecting the BTR5 to the iPhone via Bluetooth, please check whether the BTR5 is in pairing mode(Pairing showing in the display)? If not, please try to hold the volume +&- buttons at the same time for about 5s to clear the pairing or hold the multifunctional button for about 3s to enter pairing mode. Then search the BTR5 from the iPhone again.
2. If you are connect the BTR5 to the iPhone via USB, please try to turn off the charge option for the BTR5, and use the ligthning to USB C OTG adapter to check again.
Best regards
Mar 5, 2024 at 1:50 AM Post #2,030 of 2,083
Hello FiiO - quite happy with the BTR7 question is not about it, but the FiiO music app. Too many threads about it: currently on v3.2 and still doesn't see (support) .dsf DSD files while all the other apps I use (HiBy, Neutron, UAPP...) recognise and play native DSD from .dsf files. Now, FiiO music being the companion app for the BTR7 I would like to use it - but stuck with this issue. Any perspective to support .dsf DSD music in the near future? Thanks
Dear friend,
What's the problem with the DSF file with FIIO Music APP? Sorry I failed to reproduce the issue with it:
Best regards
Mar 6, 2024 at 1:34 PM Post #2,033 of 2,083
Dear friend,
Best regards
It just doesn't see the .dsf files. If I go via folder structure and I click on one file it shows "file not found" see attached
Mar 6, 2024 at 4:07 PM Post #2,034 of 2,083
I think if you switch battery protection on, it only takes effect on the next reboot. However, even then I don’t think it’s completely reliable.
Nah, rebooted so many times. I guess it's wireless charging issue, although I almost certain it worked at some point.
Mar 7, 2024 at 3:35 AM Post #2,035 of 2,083
Dear friend,
Do you mean that the battery protection mode fails to work in your BTR7 sometimes when using wireless charging? Are you using the BTR7 in latest firmware version? Thanks in advance!
Best regards
Mar 7, 2024 at 4:14 AM Post #2,036 of 2,083
Dear friend,
The engineer told me that she failed to located the issue according to information you provided. If you are convenient, please share the files to us for check.
And you could also check whether the APP downloaed from our forum for help instead: https://forum.fiio.com/note/showNoteContent.do?id=202105071626425774349&tid=17
Best regards
Mar 7, 2024 at 3:19 PM Post #2,039 of 2,083
Dear friend,
Best regards
Yes, latest FW, always charges to 100% when using wireless charger. There were few reports on this in this very thread. Looks like battery protection is just ignored.
Mar 7, 2024 at 4:28 PM Post #2,040 of 2,083
Actually, turned out it only happens with USB charge switch in OFF position. It still charges wirelessly but to full capacity instead of 80%.
