[FiiO BTR7] Portable Bluetooth Amplifier, Color IPS display,High-performance DAC ES9219C*2,THX AAA-28*2 amps,3.5+4.4mm outputs,One-click “dongle” mode
Jun 19, 2022 at 9:03 PM Post #16 of 2,095
Hi, what does the "one click" dongle mode entail?
This feature is for those who want to use BTR7 to the cell phone decoding.
At this time he will not consume the power of the phone and will not let the phone charge the battery of BTR7.
Jun 19, 2022 at 9:10 PM Post #19 of 2,095
Edit: One question - Does the new model allow you to use it's microphone when attached to the computer?
Sorry,
In UAC mode, it does not support computer-driven mic,
In Bluetooth mode, can only use the BTR7 mic
Jun 20, 2022 at 12:47 AM Post #20 of 2,095
Thanks for your time.
Doesn't BTR5 already have this? The no charge setting? How is this different?
Jun 20, 2022 at 2:12 AM Post #21 of 2,095
yes BTR5 has this selectable. maybe they made a separate button to turn this on and off instead of the way it works now where you have to hold down the power button for 2 sec and then scroll to the no charge setting or maybe it just defaults to no charge.
will this have more power than the BTR5? would be nice to have a programmable EQ with savable profiles. (more than the 1 you get now)
Jun 20, 2022 at 3:20 AM Post #22 of 2,095
Yes, similar function to BTR5 2021.
But the BTR5 series does not have a special button, you need to change the state through software or setting; BTR7 directly through the dial knob, more convenient
Jun 20, 2022 at 3:27 AM Post #23 of 2,095
Yes, it's output power is 320mW, and BTR5 is 240mW(In banlance output)
About the continuous working time,BTR7 amost the same as BTR5.
But BTR7 has a wireless charging function, can be charging power when you listening the music.
Jun 20, 2022 at 5:25 AM Post #24 of 2,095
Jun 20, 2022 at 1:02 PM Post #27 of 2,095
Is there a battery bypass mode like on Mojo 2 for use in desktop setup?
