johnston21
- Oct 25, 2005
Set the K7 to PO (headphone out), not LO (line out).
It depends on which device you want to do the digital-to-analog conversion (that’s what a DAC does - Digital to Analog Converter).Can you connect the FiiO K7 to the m11s via coaxial cable or optical cable. Is this better than using 2 rca ports? Would I get 3.5 mm port cable for the M11S and coaxial or optical cable for the other end of the cable.
They are both about equally good, but they will likely sound a little bit different:Which is better to do the conversion, the M11s or the K7
The orange extra cable in the box is what you use for the M11 to be the “transport” then get a coax digital cable (to make sure it is the correct ohmage) and you’re set… then you can decide for yourself.Which is better to do the conversion, the M11s or the K7
Yes its no different than connecting a bluetooth speaker to a TVCan you connect K7 Pro BT to a smart tv via BT?
Ok, thanks!Yes its no different than connecting a bluetooth speaker to a TV
What AV are you using? I had no problems… I wish I could permanently disable the RGB on my K9 how I could on the K7Hi everyone, I want to know if you had problems updating the software when Windows recognized the virus? The Fiio K7 looks good, but I read some reviews that they cannot update the software because Windows find a virus, although they downloaded it from the official website. This is especially true for the firmware that turns off the LED.
Well just shut down your antivirus and install it anyway.What AV are you using? I had no problems… I wish I could permanently disable the RGB on my K9 how I could on the K7
You can disable the RGB on the K9 with the FiiO app via Bluetooth.What AV are you using? I had no problems… I wish I could permanently disable the RGB on my K9 how I could on the K7
