1wyseman
- Jan 2, 2016
Yes, I'm glad you said that. Are people nuts pulling on a port? That is just asking for trouble. I hope people heed your warning.
+1 ! ! !
Easiest way is to hold the case, give a sharp shake down,
..and one slip of the hand...yikes!
Not so sure about pushing the screen, either. I'll stick with pushing it a bit through the line out hole on top using a pencil/pen eraser. (Since I'm not using the line out, I've covered it with a spare X5 plug.)
The person worried about it just slipping out on it's own while holding it upright...The Dignis case (I think FiiO case, too) is lined with a synthetic felt material that prevents slipping. That and the fact that it's constructed to be the exact correct size.
