FiiOxJadeAudio KA1/KA11 Compact Portable DAC and Amplifier Discussion & Impressions Thread
Apr 19, 2024 at 6:13 AM Post #212 of 231
Amazon Music will work if you use it on another phone. You can test it on a friend's other phone model.
In fact, it works. I am on a MI 9TPro, but seems don't fully decode in full and its only working on 48kHz.
Apr 22, 2024 at 4:40 AM Post #216 of 231
Today my KA11 (type-c black) has arrived from FiiO Aliexpress. It has already the latest firmware. Made a quick test with my Xiaomi 13T android 14 phone. Fiio control app works, Tidal recognises the KA11 so exclusive mode works.
Apr 23, 2024 at 11:13 AM Post #218 of 231
I've made some tests with KA11. On android with Tidal app as I wrote earlier the exclusive access works, but the sampling rate is not fully correct. If I play a hires file it shows the correct sample rate. Tried with 88.2 khz, 96khz, 192khz. But if I play a standard 44.1khz it shows 48khz everytime. I've tried it with PC too, it shows correctly there.
Apr 25, 2024 at 10:32 AM Post #219 of 231
I've made another tests with UAPP with multiple different sample rate files and it worked correctly. In Fiio Control app the sample rate was correct with every test files. So it seems the Tidal app is bugged. I've made test with my Fiio KA2 and it was the same. So the KA11 works correctly.
Apr 27, 2024 at 6:48 AM Post #221 of 231
I have 2 of the KA11, one for iPhone and one Android and I think the sound is amazing, but it’s the size and weight that make it so portable and hassle free compared to any of my other dongles that have earned it a special place in my collection. I don’t think you can beat this for price/performance/practicality and if I had to give away all my portable dacs and keep only one this is the one I’d keep. Pair it with an iPhone and the Hiby app or Android and the Fiio app and get a great sounding, feature packed DAP that’s perfect for local file playback!
Apr 28, 2024 at 4:39 AM Post #222 of 231
We have tested and found this problem. We are analyzing whether there is a BUG in Tidal APP or our device can be improved. If there is any progress, we will share. :beerchug:
May 3, 2024 at 3:35 AM Post #225 of 231
Anyone having disconnecting issues with their ka11? Mine is working but then it stops, I have to touch play again on the app.
Yesterday it made a pop sound, stopped and my phone couldn't play any sound through it. It would detect, the sound was coming from the phone speaker, but couldn't get the fiio ka11 to work.
The solution was just not using it for a couple of hours.
