Some people mentioned they got faulty pair ( first batch ) for the triumphs - am I the only one experiencing this! I hear fuzz when playing music using pop eq or personalized eq one with automatic like setup , but if I m doing the qe myself much normal sound less loud but less fuzzy also ,So problem with the app or the unit ? Kind of awkward
Going fully Wireless IEMs. Too soon? Or are we there yet?
- Thread starter webreaper
Somehow I connected both ear plugs thank youThe guy you should talk to is "Kai" but you will need to contact him through e mail. Go to the contact section on the website & hopefully you two connect soon.
He has more experience with TWS troubleshooting than I do.
Not so fat head
Hifiman LE for $199.
Saraguie
I don’t find a lot of differences in the NC modes. But I really have not paid attention to this feature since I don’t use it. I don’t wear them out and about.Nice. I read those were both Top notch which was the main reason I pulled the trigger .How is the transparency mode and general app and controls are they customizable?
Here's a screen shot of the button operations and a link to the owners manual. Translate in address bar works seamlessly.
https://aviot.jp/wp-content/themes/aviot/manual/te-zx1/ja/index.html#Section1-1
Is the tuning different between the ZX1 and the ZX1-PNK. There is something on the aviot page indicating the latter is warmer but I haven't seen more detail on this.I am loving my ZX1 as well
Caipirina
- May 25, 2015
- Jul 11, 2008
Only 10 units made it out to the end users. Those units have been accounted for.Some people mentioned they got faulty pair ( first batch ) for the triumphs - am I the only one experiencing this! I hear fuzz when playing music using pop eq or personalized eq one with automatic like setup , but if I m doing the qe myself much normal sound less loud but less fuzzy also ,So problem with the app or the unit ? Kind of awkward
Stay updated on Noble Audio at their sponsor profile on Head-Fi.
Wow, I actually had one of those. Feeling really old now
Same here, loving my ZX.
Only time I get connection issues is when I cross busy places like Shibuya. Tons of other signals there. ANC is spot on for train rides.
I want to hurt himHa! Yeah, that was weird…. What the hell, we’re all friends here!
davescleveland
- Jun 1, 2015
What's up with the app?Only 10 units made it out to the end users. Those units have been accounted for.
- Jul 11, 2008
That question should be sent to HQ members.What's up with the app?
Post in thread 'Going fully Wireless IEMs. Too soon? Or are we there yet?' https://www.head-fi.org/threads/goi...soon-or-are-we-there-yet.861024/post-18093504
jant71
- Feb 19, 2005
Some Nuarl news...
"Spring Headphone Festival 2024", an event where many headphone/earphone related brands gather, has begun. At the NUARL booth, there were many reference exhibits, including the "X878" completely wireless earphones equipped with MEMS drivers.
X878 is a completely wireless earphone with MEMS driver and dynamic dual driver. This model was also exhibited at last winter's "Potafes 2023 Winter Akihabara", but it has been further improved.
"X878". The round pattern on the housing will no longer be visible due to the touch sensor.
Bi-amplification drive, in which each driver is driven by a separate DAC, is also a major feature. Codecs support aptX Adaptive (up to 96kHz/24bit), aptX LL, LE Audio, etc. They hope to make further improvements and release it by the end of this year.
According to the person in charge, the interior of the earphones uses a structure in which the acoustic and digital parts are completely separated. By carefully creating the sound using only the earphones, the company's knowledge can be utilized to the fullest and the level of perfection can be further improved.
The wired earphone "X979", which was exhibited for the first time as a reference exhibit, was created during this process. Like the X878, it is a hybrid model of a MEMS driver and a dynamic dual driver.
"X979"
It is a USB-C connected model equipped with a DAC, but unlike the X878, it does not support bi-amplification. Regarding commercialization, he said that he would like to make a decision while listening to user feedback at the headphone festival venue.
Some AKG info...
Aiming to achieve high-frequency detail and high-clarity resolution, the N5 HYBRID uses a mixed material of DLC (diamond-like carbon) and PEN (polyethylene phthalate) for the diaphragm of the 10mm diameter dynamic driver. By adsorbing high-purity graphite to the PEN material using a film-forming method called the "vacuum magnetron sputtering process," they achieved both rigidity and responsiveness in the diaphragm.
Furthermore, the design of the front chamber has been revised, and the company has made improvements to the frequency response, especially after 10kHz, to provide "neutral, well-balanced, and clear sound."
Utilizing the resources of the HARMAN Group, we adopted the "oval shape design" that is also used in JBL's TWS.
The codec supports LDAC and has acquired high-resolution wireless certification set by the Japan Audio Association. Furthermore, a major feature is that a USB Type-C dongle that supports LC3+ codec is included as standard inside the charging case. For example, by using a dongle to connect to iOS devices that do not support LDAC, such as the iPhone 15 or iPad, the company claims that you can enjoy high-resolution music playback. A USB Type-A conversion adapter is also included as an accessory for connection to a PC.
Includes USB-C dongle compatible with LC3+ codec
In addition, the dongle and Bluetooth wireless can be used at the same time, and Bluetooth communication also supports multi-point connection. The product model number ``HYBRID'' refers to the seamless use of dongles and Bluetooth communication as a ``hybrid solution,'' and is named after its convenience.
As for the noise canceling function, we have adopted a design that uses the track record of high-performance microphones cultivated over many years in professional settings to achieve a balance in all frequency bands and to be more effective against crowd noise, which is the center of daily life. The company's approach to noise canceling, regardless of the brand, is that ``it's not a good thing just to make it work'', so they strongly mask only the parts that feel most uncomfortable so that the sound quality is not affected. Mr. Ishihara said that it is being completed.
There are 6 microphones for calls, including 2 beam forming microphones on the outside and 1 noise isolation microphone on the inside. In addition to noise canceling function, it also supports external sound capture function.
Regarding the microphone, it is said that it is equipped with a very high quality microphone, as it is a brand that has strong microphones even in professional models, but he emphasizes that the main feature is that it can be finely adjusted with the dedicated application "AKG Headphones App". .
Features include a ``Call Audio Equalizer'' that allows you to adjust the voice of the other party and the user's own voice in three levels, and a ``Sound Level Optimizer'' that equalizes the volume of each person's voice in situations where there are multiple speakers, such as online meetings. can be used in conjunction with the app.
One of the strengths of HARMAN International, which has multiple groups, is that it ``makes the most of the ability to share resources,'' and the housing design of this machine follows the oval shape design of JBL's ``TOUR PRO 2.'' On top of that, the company claims to have created a product that is user-friendly and typical of a professional brand, with AKG's luxurious details and a debossed finish that indicates LR in alphabetical braille on the earphones.
"X979"
Some AKG info...
jant71
- Feb 19, 2005
Lypertek(remember them)...
And from the LYPERTEK brand, a reference exhibit of the completely wireless earphones "PUREPLAY C3" will be exhibited. It uses a hybrid driver configuration with one BA driver and one dynamic driver, and the Bluetooth codec is also compatible with aptX Adaptive.PUREPLAY C3 has a long battery life that can be used for 8 hours on its own, or 1 month when used with the included charging case, and is also compatible with multi-point and IPX6 waterproofing. It is said to be priced in the late 10,000 yen range and is scheduled to be released in May.
clerkpalmer
- Dec 16, 2015
Wavelet won't work on my Pixel. Any troubleshooting? Just doesn't recognize music playing at all.
absolutnie
Have you tried legacy mode (switch in settings)?Wavelet won't work on my Pixel. Any troubleshooting? Just doesn't recognize music playing at all.
Total: 83 (members: 16, guests: 67)
