chesebert
18 Years An Extra-Hardcore Head-Fi'er
- May 17, 2004
For those with mscaler or external clock or those that still use SPDIF input, you may get better sound by connecting the ferrule on the BNC plug to the actual ground in your AC. I was dong some system optimization and measured a couple mv of offset between my BNC ground and AC ground so I attached a cable from the ferrule to the AC main ground and the offset went away and my music sounded more analog as a result. I have these ifi AC plugs with a place where you can plug in a ground cable. but there are other products that do the same thing.
Hope others can try and report back. This is essentially a free tweak if the utility is universal.
