DAPpower
so you didn't get the AGD DDC then?
No due to the uncertainty of the compatibility I opted for the Ock-2 instead but thank you so much for sharing the reply. This is good information!
Yes, I was surprised as I never believed in cable burn-in before.Glad to hear things have settled in with square wave. The cable matters far more with square wave, as I understand it. If one is finding glare with square wave, the cable could very well be the culprit. Passing a square wave with minimal harm isn’t something that’s easy for a cable to do.
That sounds exactly right as it was some time back in the R26 thread where someone figured out a way to set that pin 15 flag through an HDMI cable they modified.this is the reply to @DAPpower 's question I got, asking about compatibility:
Thank you very much for your email.
Yes the DI20HE is compatible.
DSD support
Except for pcm /DSD pin.
Most dac's have auto detect for DSD.
The Gustard not, a flag must be set on pin 15 in order to tell the dac it is DSD signal.
This could be a manual trigger of DSD is important for you. Would require a mod in the DI20HE.
Let me know if you have any questions
Regards
Jos
Magna Hifi
Yes and modifying that pin only necessary for Dsd files.That sounds exactly right as it was some time back in the R26 thread where someone figured out a way to set that pin 15 flag through an HDMI cable they modified.
After the 200 hour-burn in period, you can also try switching the direction / orientation of the HT DC 3 cable.To me, the Sinewave sounds more analog which I prefer, Squarewave is too peaky and to me it sounds like what I would call digital glare.
I also find myself using EXT clock mode on the X26 Pro and INT mode on the U18 as of late. I still have the U18 hooked to the Ock-2 but on INT mode if that even makes a difference. If I turn on EXT mode on U18 the soundstage is ruined, everything sounds collapsed and distant.
Maybe you want to get it sometime later knowing that mode 2 is the one compatible with X26pro...No due to the uncertainty of the compatibility I opted for the Ock-2 instead but thank you so much for sharing the reply. This is good information!
New ones are available for short money. https://www.ebay.com/itm/166090781988my remote stopped working, anyone using a replacement?
The Matrix Element H looks like a very nice choice. I suspect there will be nice additive gains from using the Matrix Element H to feed the U18.In this case, will a DDC (eg. Gustard U18/ Matrix X-SPDIF 3) improve the sound any further? If I use the I2S output from the DDC, then the DAC would follow the clock in the DDC (pls correct me if I am wrong), so if the clock in the DDC (K2 in the Gustard U18/ Accusilicon in the X-SPDIF 3) isn't better than that in the DAC (Gustard K2), then will there be any benefit from using the "clean" signal from the Matrix Element H USB output on the computer?
