HiBy FC6--R2R dongle DAC reborn
The PULA PA02 are confirmed to be born to play with the Hiby FC6... I can't wait to try the new reference iems the SLIIVO SL-41 (with greater definition than the PA02) and the SLIIVO SLT6 (6 BA) with the Hiby FC6... will definitely be two more fantastic synergies.
makbrown
Guys, simple question. Android + hiby music + tidal hifi plus + fc6. Does not output mqa to the device. Exclusive mode enabled. What is missing?
ClintonL
- Mar 15, 2012
Wondering what the best settings to use with the fc6 are?
Lexington99
I have ordered the FC6, couldn't resist anymore at the price of $180. Had the RU6 at one point, but found it terribly noisy and unrefined, musical but kind of low-fi.
Going to be using the FC6 alongside my trusty xDuoo Link2Bal Max to drive BQEYZ Wind, ZiiGaat Doscinco, MiM Dark Magician OG & TinHifi P1 Max.
It's going to be interesting to see how well it can drive P1 Max & Wind, both of which are quite power hungry.
More impressions of FC6 is always welcome.
HifiGo Spring deals?I have ordered the FC6, couldn't resist anymore at the price of $180. Had the RU6 at one point, but found it terribly noisy and unrefined, musical but kind of low-fi.
I ordered one from there a few days ago, and I'm looking forward to hearing the FC6. It will be my first experience with "R2R"
Lexington99
Yes!HifiGo Spring deals?
Let us report back here once we've had a listen, to share our thoughts
The only thing I'm anxious about regarding the FC6 is the stage, specifically width.
Dongles that sound narrow (Questyle M15 for example) I cannot find enjoyment from.
That is one element that the Link2Bal Max excels in, stage size.
SureYes!
I don't have that much to compare it against, though. But will try and compare it with the Moondrop Dawn and my Violectric V200/SMSL DO100 stack. The last one is a bit unfair, but to me, still interesting.
Joe Bloggs
Sponsor: HiByMember of the Trade: EFO Technologies Co, YanYin TechnologyHis Porta Corda walked the Green Mile
What kind of sound are you after? In any case check for firmware updates here: https://store.hiby.com/apps/help-centerWondering what the best settings to use with the fc6 are?
Stay updated on HiBy at their facebook, website or email (icons below).
Stay updated on HiBy at their sponsor profile on Head-Fi.
Singaravelan
I still haven't updated Fc6, only! Windows computer access issue! And I fell in love with the NOS option. Should update and explore.What kind of sound are you after? In any case check for firmware updates here: https://store.hiby.com/apps/help-center
makbrown
I updated to the latest version. The differences in sound between the filters, including the branded Darwin, are so insignificant that they are even not worth the time spent on description. It sounds great in NOS. I listen exclusively mode on the Tidal iOS app or Hiby music on Android.I still haven't updated Fc6, only! Windows computer access issue! And I fell in love with the NOS option. Should update and explore.
Joe Bloggs
what sample rate are you listening at?I updated to the latest version. The differences in sound between the filters, including the branded Darwin, are so insignificant that they are even not worth the time spent on description. It sounds great in NOS. I listen exclusively mode on the Tidal iOS app or Hiby music on Android.
If you're listening at over 48kHz (88.2 or above), I won't argue that the differences are insignificant.
makbrown
Everything that comes with a max Tidal subscription. from flac 16/44 to 24/192 and MQA. I tried many times to hear the difference, but I only hear between NOS/OS, and not between filters in OS. The same is the zero impact of HDR.what sample rate are you listening at?
And by the way, even before purchasing fc6, when I looked and read reviews, they noted that they did not hear HDR on/off at all, and the influence of filters was extremely minimal.
Did you receive any updates on your order? I was just told that mine probably will ship in mid April, even though it was in stock when I placed the order :/Yes!
Have asked them to cancel the order, might as well just go with the Mojo2 or RU7 instead.
Lexington99
Man that's rough. If I were you, I would hold on to the FC6 because:Did you receive any updates on your order? I was just told that mine probably will ship in mid April, even though it was in stock when I placed the order :/
1. FC6 on sale is a whole lot cheaper ($180) vs $299 for RU7.
2. The vast majority prefer the FC6 to the RU7, as great as RU7 probably is.
If it makes you feel any better, my FC6 is stuck in customs since 21/3 Hifigo has contacted the carrier for me. We'll see how it goes.
